.NET
Insert into ACAD 2010 .NET App
1 REPLY 1
scott.cleveland
317 Views, 1 Reply
I ahve a .net app which I want to have an insert occur but wnat to use the insert dialog built into autocad.
If I call:
m_objAcadApplication.ActiveDocument.SendCommand("INSERT\r");
I get the dialog, then through win32 api calls I can set the path and the block name on the dialog, but if I click OK the insert does not work - it will only work if I click the browse button and browse to the file name I just set. I did this also w/ win32 api (have select drawing file dialog) and set the filename, and then click the open button via win32 api - but it looks hacky.. Anyone know how the have the initial insert dialog go forward w/ the insert and not have to go w/ the select drawing dialog? Thanks Scott
1 REPLY 1
in reply to: scott.cleveland
The drawing file that's inserted is not stored in the path label, it's
stored in a private member variable that you can't get to.
Sorry to ask, but what is the point to this, verses just building your own
UI?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message
news:6270390@discussion.autodesk.com...
If I call:
”Boost
