.NET
Insert existing block VB.NET
12 REPLIES 12
Message 1 of 13
sgrya1
2835 Views, 12 Replies
I've found out how to copy a block from another drawing into the current one.
Can someone give me some sample code of how to insert that same block?
It's a dynamic block and I need to change the properties on insert so any suggestions there would be helpful.
12 REPLIES 12
Message 2 of 13
in reply to: sgrya1
{quote}
{quote}
search this newsgroup for code samples (yes there are few showing
this),
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6345257@discussion.autodesk.com...
suggestions there would be helpful. Edited by: Discussion_Admin on Mar 1, 2010 5:52 PM
Message 3 of 13
sgrya1
in reply to: sgrya1
🙂 I have searched the forum. Code examples are in C or don't explain how to reinsert the same block without renaming it from what I have found. Edited by: Discussion_Admin on Mar 1, 2010 5:53 PM
Message 4 of 13
NathTay
in reply to: sgrya1
There is plenty of documentation available on what you want to do. This is not a place for you to learn how to program rather a place for people to get help when they have a specific issue.
Message 5 of 13
sgrya1
in reply to: sgrya1
I do have a specific problem. See the OP. Edited by: Discussion_Admin on Mar 1, 2010 5:59 PM
Message 6 of 13
in reply to: sgrya1
{quote}
{quote}
The code samples aren't in C, but then again, you probably
aren't able to distinguish between C and C# .
Edited by: Discussion_Admin on Mar 1, 2010 6:01 PM
Message 7 of 13
sgrya1
in reply to: sgrya1
Just found these training labs.
http://images.autodesk.com/adsk/files/autocad_2010_dotnet_training.zip
Lab 3 shows the method for re-inserting blocks using vb.
Message 8 of 13
in reply to: sgrya1
Search for DynamicBlockReferencePropertyCollection.
Keep working at it and you'll get there.
Terry Edited by: Discussion_Admin on Mar 1, 2010 6:05 PM
Message 9 of 13
sgrya1
in reply to: sgrya1
Thanks Terry. It's a bit disturbing. Edited by: Discussion_Admin on Mar 1, 2010 6:04 PM
Message 10 of 13
NathTay
in reply to: sgrya1
Yes you do have a specific problem. Edited by: Discussion_Admin on Mar 1, 2010 6:00 PM
Message 11 of 13
NathTay
in reply to: sgrya1
Good to see Edited by: Discussion_Admin on Mar 1, 2010 6:03 PM
Message 12 of 13
sgrya1
in reply to: sgrya1
Wasn't so easy to find but is a great supporting tutorial.
Hopefully this thread helps others who need similar guidance.
Message 13 of 13
sgrya1
in reply to: sgrya1
Just a specific problem linked to a solution. Insert existing block using VB.NET.
Nothing special about it.
”Boost
