.NET
Insert Dynamic Block
8 REPLIES 8
Message 1 of 9
GegH1
706 Views, 8 Replies
I am trying to insert a dynamic block and position and stretch the block, using the linear parameters, depending on values entered into a form.
Has anyone done anything similar. I managed to create a form that would draw a series of boxes. And i managed to create a routine that would insert a block and size it depending on fixed values but i can't link the 2 together.
I'm more than happy to share what i have so far if someone is willing to help
Creative Intentions
Win 10 Pro 64bit, HP ZBook 17
8 REPLIES 8
Message 2 of 9
Alexander.Rivilis
in reply to: GegH1
Dynamic Block with Stretch Action
How to access and modify a DynamicBlockReference property in ARX and .Net?
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 3 of 9
GegH1
in reply to: GegH1
Is this run from a form?
Creative Intentions
Message 4 of 9
Alexander.Rivilis
in reply to: GegH1
And why not? You've already tried?
Expert Elite Member
Message 5 of 9
GegH1
in reply to: Alexander.Rivilis
I've got the code that manipulates the block,i can't however get it to work with a form, how does your code differ from that?
Creative Intentions
Message 6 of 9
DiningPhilosopher
in reply to: GegH1
You're asking someone to tell you how their code differs from what?  Your code?
Are you expecting an answer without seeing your code?
Message 7 of 9
GegH1
in reply to: DiningPhilosopher
Here's the code i'm using which works with the attched drawing. The last bit with hard coded values manipulates the block, i need a form to put the numbers in
Imports
Autodesk.AutoCAD.Runtime
Imports
Autodesk.AutoCAD
Imports
Autodesk.AutoCAD.DatabaseServices
Imports
Autodesk.AutoCAD.EditorInput
Imports
Autodesk.AutoCAD.Geometry
Imports
Autodesk.AutoCAD.ApplicationServices
Imports
Autodesk.AutoCAD.ApplicationServices.Application
Imports
Autodesk.AutoCAD.LayerManager
Imports
Autodesk.AutoCAD.Windows
Imports
System.Math
Public
ClassCommands
CommandMethod("DrawShed")> _
PublicSub DrawShed()
Dim recFrm AsNewShedForm()
Application.ShowModelessDialog(recFrm)
EndSub
End
Class
Public
ClassRectangle
PublicFunction InsertBlock(ByVal DatabaseIn AsDatabase, _
ByVal BTRToAddTo AsString, _
ByVal InsPt As Geometry.Point3d, _
ByVal BlockName AsString, _
ByVal XScale AsDouble, _
ByVal YScale AsDouble, _
ByVal ZScale AsDouble) As DatabaseServices.ObjectId
Using myTrans AsTransaction = DatabaseIn.TransactionManager.StartTransaction
Dim myBlockTable AsBlockTable = DatabaseIn.BlockTableId.GetObject(OpenMode.ForRead)
'If the suppplied Block Name is not
'in the specified Database, get out gracefully.
If myBlockTable.Has(BlockName) = FalseThen
ReturnNothing
EndIf
'If the specified BlockTableRecord does not exist,
'get out gracefully
If myBlockTable.Has(BTRToAddTo) = FalseThen
ReturnNothing
EndIf
Dim myBlockDef AsBlockTableRecord = _
                myBlockTable(BlockName).GetObject(
OpenMode.ForRead)
Dim myBlockTableRecord AsBlockTableRecord = _
myBlockTable(BTRToAddTo).GetObject(
OpenMode.ForWrite)
'Create a new BlockReference
Dim myBlockRef AsNewBlockReference(InsPt, myBlockDef.Id)
'Set the scale factors
            myBlockRef.ScaleFactors =
New Geometry.Scale3d(XScale, YScale, ZScale)
'Add the new BlockReference to the specified BlockTableRecord
            myBlockTableRecord.AppendEntity(myBlockRef)
'Add the BlockReference to the BlockTableRecord.
            myTrans.AddNewlyCreatedDBObject(myBlockRef,
True)
Dim myAttColl As DatabaseServices.AttributeCollection = _
                myBlockRef.AttributeCollection
'Find Attributes and add them to the AttributeCollection
'of the BlockReference
ForEach myEntID AsObjectIdIn myBlockDef
Dim myEnt AsEntity = myEntID.GetObject(OpenMode.ForRead)
IfTypeOf myEnt Is DatabaseServices.AttributeDefinitionThen
Dim myAttDef As DatabaseServices.AttributeDefinition = myEnt
Dim myAttRef AsNew DatabaseServices.AttributeReference
                    myAttRef.SetAttributeFromBlock(myAttDef, myBlockRef.BlockTransform)
                    myAttColl.AppendAttribute(myAttRef)
                    myTrans.AddNewlyCreatedDBObject(myAttRef,
True)
EndIf
Next
            myTrans.Commit()
Return myBlockRef.Id
EndUsing
EndFunction
Function SetParameter(ByVal BlockID AsObjectId, ByVal ParameterName AsString, _
ByVal Value AsDouble) AsBoolean
Using myTrans AsTransaction = BlockID.Database.TransactionManager.StartTransaction
Dim myBRef AsBlockReference = BlockID.GetObject(OpenMode.ForRead)
ForEach myDynamProp AsDynamicBlockReferencePropertyIn _
                    myBRef.DynamicBlockReferencePropertyCollection
If myDynamProp.PropertyName.Equals( _
                        ParameterName,
StringComparison.OrdinalIgnoreCase) = TrueThen
                    myDynamProp.Value = Value
                    myTrans.Commit()
ReturnTrue
Exit For
EndIf
Next
ReturnFalse
EndUsing
EndFunction
Private _length AsDouble
PublicProperty Length() AsDouble
Get
Return _length
EndGet
Set(ByVal value AsDouble)
            _length = value
EndSet
EndProperty
Private _width AsDouble
PublicProperty Width() AsDouble
Get
Return _width
EndGet
            _width = value
EndSet
EndProperty
Private _height AsDouble
PublicProperty Height() AsDouble
Get
Return _height
EndGet
            _height = value
EndSet
EndProperty
Private _slope AsDouble
PublicProperty slope() AsDouble
Get
Return _slope
EndGet
            _slope = value
EndSet
EndProperty
SubNew(ByVal length AsDouble, ByVal width AsDouble, ByVal height AsDouble, ByVal slope AsDouble)
Me.Length = length
Me.Width = width
Me.Height = height
Me.slope = slope
EndSub
PublicSub InsertBlockSetPointParameter()
Dim doc AsDocument = Application.DocumentManager.MdiActiveDocument
Dim db AsDatabase = doc.Database
Dim radians AsDouble = slope * PI / 180
Dim RL AsDouble = Tan(radians) * (Width / 2)
Dim TP AsDouble = Height + RL
Dim myBlockID AsObjectId = InsertBlock(HostApplicationServices.WorkingDatabase, _
BlockTableRecord.ModelSpace, _
NewPoint3d(1, 1, 0), "Plan_Base", 1, 1, 1)
        SetParameter(myBlockID,
"P_Len", Length)
"P_Width", Width)
"Ridge_Height_LE", TP)
"Ridge_Height_RE", TP)
"Shed_Height_LE", Height)
"Shed_Height_RE", Height)
"Shed_Height_Front", Height)
"Ridge_Height_Front", TP)
"Shed_Height_Back", Height)
"Ridge_Height_Back", TP)
EndSub
End
Class
Creative Intentions
Message 8 of 9
GegH1
in reply to: GegH1
It seems i am getting an eLockViolation
OpenMode.ForWrite)
Full Function
Public
ClassInsBlock
ReturnNothing
EndIf
'get out gracefully
ReturnNothing
EndIf
OpenMode.ForRead)
OpenMode.ForWrite)
True)
True)
EndIf
Next
            myTrans.Commit()
EndUsing
EndFunction
Creative Intentions
Message 9 of 9
Alexander.Rivilis
in reply to: GegH1
Please using search to find such ubiquitous errors: eLockViolation
Expert Elite Member
”Boost
