.NET
.NET
BrentBurgess1980
Message 1 of 4 (331 Views)
Insert Dymanic Block from file and changeVisibility States
331 Views, 3 Replies
12-19-2011 06:26 PM
I am trying to insert a Dynamic Block and change it's Visibility State. I can insert the block, and the visibility state changes, however, if I manually try to change it after, it does not change, even though the value has changed. My code executes and returns no errors, so I am assuming that I have done something wrong, or missed something out.
 public class MyCommands
        [CommandMethod("MyGroup", "Bolts", "MyCommandLocal", CommandFlags.Modal)]
        public void MyCommand() // This method can have any name
            InsertBlock(Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database, "C:/88NutPlan.dwg", new Point3d(0, 0, 0));
        public static void InsertBlock(Database db, string FileName, Point3d InsertionPoint, double Rotation = 0)
            ObjectId blkid = ObjectId.Null;
            using (Database bdb = new Database(false, true))
                bdb.ReadDwgFile(FileName, System.IO.FileShare.Read, true, "");
                blkid = db.Insert(System.IO.Path.GetFileNameWithoutExtension(FileName), bdb, true);
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
                    BlockTableRecord btr = default(BlockTableRecord);
                    btr = (BlockTableRecord)tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
                    using (btr)
                        BlockReference bref = new BlockReference(InsertionPoint, blkid);
                        using (bref)
                            if (bref.IsDynamicBlock)
                                DynamicBlockReferencePropertyCollection dynBrefColl = bref.DynamicBlockReferencePropertyCollection;
                                foreach (DynamicBlockReferenceProperty dynBrefProps in dynBrefColl)
                                    if (dynBrefProps.PropertyName == "Visibility1")
                                        dynBrefProps.Value = "M36";
                            Matrix3d mat = Matrix3d.Identity;
                            bref.TransformBy(mat);
                            bref.Layer = "0";
                            bref.Rotation = Rotation;
                            btr.AppendEntity(bref);
                            tr.AddNewlyCreatedDBObject(bref, true);
                    tr.Commit();
If I insert my block manually, I can change the states and it works fine, but the code seems to break the block.
Can anyone shed some light on this?
Hallex
Message 2 of 4 (313 Views)
Re: Insert Dymanic Block from file and changeVisibility States
12-20-2011 12:51 AM in reply to: BrentBurgess1980
You have to change order of your work with block
See if this working for you :
            using (btr)
                             bref.Layer = "0";
                                     if (dynBrefProps.PropertyName.ToUpper() == "VISIBILITY1")
                     tr.Commit();
BrentBurgess1980
Message 3 of 4 (287 Views)
12-20-2011 04:00 PM in reply to: Hallex
Thanks Hallex - That worked perfeclty!!
Hallex
Message 4 of 4 (278 Views)
12-20-2011 10:46 PM in reply to: BrentBurgess1980
You're welcome
Cheers :smileyhappy:
~'J'~
