Insert block with attributes into a side database
Keith.Brown
Advisor Advisor
Keith.Brown
I have been unsuccessful with trying to insert a block with attributes into a side database.  I have been able to insert one successfully into an active database but not a side one.  Here is my insert block code.
/// <summary>
/// Inserts a block into the specified Space.
/// </summary>
/// <param name="blockName">Name of the block to insert.</param>
/// <param name="insertionPoint">The insertion point of the block.</param>
/// <param name="database">The database to work in.</param>
/// <param name="space">The space to insert into</param>
/// <param name="attributes">The attributes to set on the block.</param>
/// <exception cref="System.ArgumentNullException">blockName;The block name cannot be empty</exception>
/// <exception cref="Autodesk.AutoCAD.Runtime.Exception">The database cannot be null.
/// or
/// The block does not exist in the current database.</exception>
/// <exception cref="Exception">
/// </exception>
public static void InsertBlock(string blockName, Point3d insertionPoint, Database database, Space space, Dictionary<string, string> attributes)
   if (string.IsNullOrWhiteSpace(blockName))
      throw new ArgumentNullException("blockName", "The block name cannot be empty");
   if (database == null)
      throw new Exception(ErrorStatus.NoDatabase, "The database cannot be null.");
   using (var transaction = database.TransactionManager.TopTransaction)
      if (transaction == null)
         throw new Exception(ErrorStatus.NotTopTransaction);
      var blockTable = (BlockTable)database.BlockTableId.GetObject(OpenMode.ForRead);
      if (!blockTable.Has(blockName))
         throw new Exception(ErrorStatus.NotInDatabase, "The block does not exist in the current database.");
      var blockDefinition = (BlockTableRecord)blockTable[blockName].GetObject(OpenMode.ForRead);
      using (var blockReference = new BlockReference(insertionPoint, blockDefinition.ObjectId))
         try
            BlockTableRecord currentSpace;
            if (space == Space.ModelSpace)
               currentSpace = (BlockTableRecord)blockTable[BlockTableRecord.ModelSpace].GetObject(OpenMode.ForWrite);
            else
               currentSpace = (BlockTableRecord)blockTable[BlockTableRecord.PaperSpace].GetObject(OpenMode.ForWrite);
            currentSpace.AppendEntity(blockReference);
            transaction.AddNewlyCreatedDBObject(blockReference, true);
            foreach (var objectId in blockDefinition)
               var dbObject = objectId.GetObject(OpenMode.ForRead);
               var attributeDefinition = dbObject as AttributeDefinition;
               if ((attributeDefinition != null) && (!attributeDefinition.Constant))
                  if (attributes.ContainsKey(attributeDefinition.Tag))
                     using (var attributeReference = new AttributeReference())
                        try
                           attributeReference.SetAttributeFromBlock(attributeDefinition, blockReference.BlockTransform);
                           attributeReference.Position = attributeDefinition.Position.TransformBy(blockReference.BlockTransform);
                           attributeReference.TextString = attributes[attributeDefinition.Tag];
                           blockReference.AttributeCollection.AppendAttribute(attributeReference);
                           transaction.AddNewlyCreatedDBObject(attributeReference, true);
                        catch (Exception exception)
                           Log.Logger.Error(exception, "Unable to set attribute {Attribute} on block {blockName}", attributeDefinition.TextString, blockName);
            Log.Logger.Error(exception, "Unable to insert the block {blockName} into the drawing {fileName}.", blockName, database.Filename);
            throw new Exception(ErrorStatus.UnrecoverableErrors, string.Format("Unable to insert block {0} into {1}.", blockName, database.Filename), exception.InnerException);
Here are the commands to run the code.
/// <summary>
/// Imports a block and inserts it into the current drawing.
/// </summary>
[CommandMethod("My Examples", "ImportAndInsertBlockIntoActiveDrawing", CommandFlags.Session)]
public void ImportAndInsertBlockIntoActiveDrawingCSharpCommand()
   var database = Active.Database;
   using (Active.Document.LockDocument())
   using (var transaction = database.TransactionManager.StartTransaction())
      var objectId = BlockUtils.ImportBlock("test", @"C:\Users\kbrown\Desktop\TestBlock.dwg", database, DuplicateRecordCloning.Replace);
      if (objectId != ObjectId.Null)
         var attributes = new Dictionary<string, string> { { "SCALE", "1/8\" = 1'-0\"" }, { "TITLE", "This is where the title block goes." } };
         BlockUtils.InsertBlock("test", new Point3d(0, 0, 0), database, Space.PaperSpace, attributes);
      else
         MessageBox.Show("Unable to import the block.", "Import Error!");
      transaction.Commit();
/// <summary>
/// Imports the block and inserts it into a side drawing.
/// </summary>
[CommandMethod("My Examples", "ImportAndInsertBlockIntoSideDrawing", CommandFlags.Session)]
public void ImportAndInsertBlockIntoSideDrawingCSharpCommand()
   const string FileName = @"C:\Users\kbrown\Desktop\TempTestDrawing.dwg";
   var database = new Database();
   database.ReadDwgFile(FileName, FileOpenMode.OpenForReadAndAllShare, true, string.Empty);
   database.SaveAs(FileName, DwgVersion.Current);
As I mentioned before inserting into an active database works with no issues.  Inserting into a side database will insert the block but no attributes.  If i open the drawing afterwards and insert the block then the attributes work normal so i know that there is nothing wrong with my import function.  (at least i belive that is a true statement).
Anyone have any ideas? Thanks.
Drawing with block to place on desktop.  (Make sure to change filename string to point to correct location if downloading for testing.)
TestBlock.dwg
_gile
No time to check what's wrong with your code, but the following code works for me.
Maybe you can get some inspiration...
Some extension methods:
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
using System;
using System.Collections.Generic;
using System.IO;
using AcRx = Autodesk.AutoCAD.Runtime;
namespace ImportBlock
    static class BlockUtils
        public static ObjectId GetBlock(this BlockTable blockTable, string blockName)
            if (blockTable == null)
                throw new ArgumentNullException("blockTable");
            Database db = blockTable.Database;
            if (blockTable.Has(blockName))
                return blockTable[blockName];
            try
                string ext = Path.GetExtension(blockName);
                if (ext == "")
                    blockName += ".dwg";
                string blockPath;
                if (File.Exists(blockName))
                    blockPath = blockName;
                else
                    blockPath = HostApplicationServices.Current.FindFile(blockName, db, FindFileHint.Default);
                blockTable.UpgradeOpen();
                using (Database tmpDb = new Database(false, true))
                    tmpDb.ReadDwgFile(blockPath, FileShare.Read, true, null);
                    return blockTable.Database.Insert(Path.GetFileNameWithoutExtension(blockName), tmpDb, true);
            catch
                return ObjectId.Null;
        public static BlockReference InsertBlockReference(
            this BlockTableRecord target,
            string blkName,
            Point3d insertPoint,
            Dictionary<string, string> attValues = null)
            if (target == null)
                throw new ArgumentNullException("target");
            Database db = target.Database;
            Transaction tr = db.TransactionManager.TopTransaction;
            if (tr == null)
                throw new AcRx.Exception(ErrorStatus.NoActiveTransactions);
            BlockReference br = null;
            BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
            ObjectId btrId = bt.GetBlock(blkName);
            if (btrId != ObjectId.Null)
                br = new BlockReference(insertPoint, btrId);
                BlockTableRecord btr = (BlockTableRecord)tr.GetObject(btrId, OpenMode.ForRead);
                target.AppendEntity(br);
                tr.AddNewlyCreatedDBObject(br, true);
                br.AddAttributeReferences(attValues);
            return br;
        public static void AddAttributeReferences(this BlockReference target, Dictionary<string, string> attValues)
            if (target == null)
            Transaction tr = target.Database.TransactionManager.TopTransaction;
            if (tr == null)
            BlockTableRecord btr = (BlockTableRecord)tr.GetObject(target.BlockTableRecord, OpenMode.ForRead);
            RXClass attDefClass = RXClass.GetClass(typeof(AttributeDefinition));
            foreach (ObjectId id in btr)
                if (id.ObjectClass != attDefClass)
                    continue;
                AttributeDefinition attDef = (AttributeDefinition)tr.GetObject(id, OpenMode.ForRead);
                AttributeReference attRef = new AttributeReference();
                attRef.SetAttributeFromBlock(attDef, target.BlockTransform);
                if (attValues != null && attValues.ContainsKey(attDef.Tag.ToUpper()))
                    attRef.TextString = attValues[attDef.Tag.ToUpper()];
                target.AttributeCollection.AppendAttribute(attRef);
                tr.AddNewlyCreatedDBObject(attRef, true);
Testing commands
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.EditorInput;
using AcAp = Autodesk.AutoCAD.ApplicationServices.Application;
[assembly: CommandClass(typeof(ImportBlock.Commands))]
    public class Commands
        [CommandMethod("Cmd1")]
        public void Cmd1()
            Document doc = AcAp.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                ObjectId btrId = bt.GetBlock(@"F:\gile\Gile_blocs\bloc-att.dwg");
                if (btrId == ObjectId.Null)
                    return;
                Dictionary<string, string> attValues = new Dictionary<string,string>();
                attValues.Add("ATT1", "foo");
                attValues.Add("ATT2", "bar");
                BlockTableRecord curSpace = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                BlockReference br = curSpace.InsertBlockReference("bloc-att", Point3d.Origin, attValues);
                tr.Commit();
        [CommandMethod("Cmd2")]
        public void Cmd2()
            const string filename = @"F:\gile\TestDrawing.dwg";
            using (Database db = new Database(false, true))
                db.ReadDwgFile(filename, System.IO.FileShare.ReadWrite, false, null);
                        return;
                    Dictionary<string, string> attValues = new Dictionary<string, string>();
                    tr.Commit();
                db.SaveAs(filename, DwgVersion.Current);
Gilles Chanteau
GileCAD
GitHub
Keith.Brown
Thanks Gile.  Through your code i was able to figure out that the code that I had posted had nothing wrong with it.  The issue was with the importing of blocks.  I was using wblock clone to go out into a drawing and bring in a specific block.  Somehow this is/was causing an ewrongdatabase exception whenever I was appending the attribute references to the block reference but only in a side database.  Instead of tracing it down I just did something similar to your GetBlock function.  I just imported the entire dwg as a block instead.  If and when i need multiple blocks inserted into a side database from the same drawing i will revisit the issue.  Until then what I have is working great.
Thanks for the help.
