.NET
Insert block with attributes in existing table
2 REPLIES 2
Gaituuth
707 Views, 2 Replies
I'm creating a routine to fill in my terminal strips. This routine worked perfectly in Vba but I'm now rewriting it for .NET
The problem is that I want to insert a block with attributes into different cells.
The tables already exists. Below my function, I'm stuck on this part
Dim lonReturnedIds = FunBlockId() ' Calls the function FunBlockID to get the ID's of the attributes
' 0 = BlockID
' 1 = AttributeID of KleurB
' 2 = AttributeID of KleurO
TS.Cells(i, intPosition).Contents.Add()
TS.Cells(i, intPosition).Contents(0).BlockTableRecordId = lonReturnedIds(0)
TS.Cells(i, intPosition).SetBlockAttributeValue(lonReturnedIds(1), strCableConductor2WriteFirst)
Thanks in advance.
Gerald
    Public Function Fun_StripUp(ByVal Po3dXY As Point3d, ByVal str_CableName As String, ByVal Str_CableConductor As String, ByVal strCableConductor2Write As String, ByVal strCableConductor2WriteFirst As String, ByVal intPosition As Integer) As String
        Dim tAcadDoc As ApplicationServices.Document = ApplicationServices.Application.DocumentManager.MdiActiveDocument
        Dim myDB As DatabaseServices.Database
        Dim myDWG As ApplicationServices.Document
        Dim myEd As EditorInput.Editor
        Dim myPSR As EditorInput.PromptSelectionResult
        Dim mySS As EditorInput.SelectionSet
        Dim myFilter(0) As DatabaseServices.TypedValue
        myFilter(0) = New DatabaseServices.TypedValue(DatabaseServices.DxfCode.Start, "ACAD_TABLE")
        ' myFilter(0) = New DatabaseServices.TypedValue(DatabaseServices.DxfCo​de.Start, "POLYLINE")
        ' myFilter(0) = New DatabaseServices.TypedValue(DatabaseServices.DxfCo​de.Start, "MTEXT")'''
        ' Change items commented out above for testing.
        Dim mySF As New EditorInput.SelectionFilter(myFilter)
        myDWG = ApplicationServices.Application.DocumentManager.MdiActiveDocument
        myDB = myDWG.Database
        myEd = myDWG.Editor
        myPSR = myEd.SelectAll(mySF)
        Dim GetInfofromIni As New Readini
        Dim str_CableNumber_UP As Integer = GetInfofromIni.IniInfo("External", "FieldNumber_Cable")
        Dim tTrAct As DatabaseServices.Transaction = Nothing
        Try
            mySS = myPSR.Value
            tTrAct = tAcadDoc.TransactionManager.StartTransaction
            If Not IsNothing(mySS) Then
                ' MsgBox(mySS.Count)
                For Each tObjID As DatabaseServices.ObjectId In myPSR.Value.GetObjectIds
                    'here we go through the returned ObjectID's
                    'Dim e As Entity = tTrAct.GetObject(tObjID, OpenMode.ForWrite)
                    Dim TS As Table = tTrAct.GetObject(tObjID, OpenMode.ForWrite)
                    If TS.Position <> Po3dXY Then
                        'MsgBox("No action will be taken")
                    Else
                        'MsgBox(TS.Position)
                        Dim itotaal = TS.Rows.Count
                        Dim itotal_columns = TS.Columns.Count
                        Dim i As Integer
                        'Dim ii = 0
                        i = itotaal - 1
                        Do While i > 0
                            Dim strCableNumber = TS.Cells(i, str_CableNumber_UP).TextString
                            If strCableNumber = "" Then
                                TS.Cells(i, str_CableNumber_UP).TextString = str_CableName
                                'we have to determine the position for the cable conductor
                                ' also check for the conductor numbers, if it's only 2 then nothing
                                ' else we have place a block inside the cellvalue
                                ' kleur2 is for conductor with 3 or 4 characters
                                If strCableConductor2Write <> "" Then
                                    If strCableConductor2WriteFirst = "" Then
                                        TS.Cells(i, intPosition).TextString = strCableConductor2Write
                                        TS.Cells(i, intPosition).Alignment = CellAlignment.MiddleCenter
                                    Else
                                        ' 0 = BlockID
                                        TS.Cells(i, intPosition).SetBlockAttributeValue(lonReturnedIds(1), "TTEEST")
                                        TS.Cells(i, intPosition).SetBlockAttributeValue(lonReturnedIds(2), "TTEEST")
                                    End If
                                Else
                                    TS.Cells(i, intPosition).TextString = Str_CableConductor
                                End If
                                GoTo endfunction
                            End If
                            i = i - 1
                        Loop
                    End If
                Next
EndFunction:
                tTrAct.Commit()
            End If
        Catch ex As SystemException
            MsgBox(Err.Description)
        Finally
            If tTrAct IsNot Nothing Then tTrAct.Dispose() : tTrAct = Nothing
        End Try
        Return Nothing
    End Function
2 REPLIES 2
chiefbraincloud
in reply to: Gaituuth
Try this post:
http://through-the-interface.typepad.com/through_the_interface/2007/06/creating_an_aut_1.html
The original post does not deal with attributes, but there is some activity in the comments that talks about how to do it.
Gaituuth
in reply to: chiefbraincloud
Thanks for your reply, I already had seen that post.
But when I now looked at the code I saw my mistake.
It should be
TS.UpgradeOpen()
                                            TS.Cells(i, intPosition).BlockTableRecordId = lonreturnedIds(0)
Again thanks.
”Boost
