.NET
.NET
Hallex
Message 11 of 35 (277 Views)
Re: Insert Block on Multiple Selected Points
04-26-2012 09:06 AM in reply to: bkenyon13
Please, explain a bit more
Do you want to select the objects inside the circles, ellipses, splines?
~'J'~
Active Contributor
bkenyon13
Message 12 of 35 (266 Views)
04-27-2012 09:18 AM in reply to: Hallex
Sorry if it is hard to follow I have trouble explaining things easily.
Basically I would like to be able to do is place blocks at the end points of polylines and lines as well as on nodes on point entities.
I don't want to be restricted to only polylines.
Hallex
Message 13 of 35 (256 Views)
04-27-2012 10:48 AM in reply to: bkenyon13
You can retrieve startpoint and endpoint of entities easily in this case,
sorry, i can't help right now, coz i'm a bit busy yet
~'J'~
Active Contributor
bkenyon13
Message 14 of 35 (242 Views)
04-30-2012 08:46 AM in reply to: Hallex
I understand and thank you for all your help to this point Hallex.
I have worked on some code to try and get it to also select the start and end points of a line and also select point entities, but it is not working right and I am not sure that I have the code correct.
I have attach a txt file with all my code it it, if anyone can look at it and let me know what I am doing wrong.
if someone could easily point out what I have wrong and tell me what it is I should be able to get it fixed, but I am a little lost at this point.
Thanks to all you can assist.
Active Contributor
bkenyon13
Message 15 of 35 (234 Views)
04-30-2012 09:58 AM in reply to: bkenyon13
ok, I have got the code workign for polylines as well as lines.
I am still working on the point entities part of it.
I have split the code into two seperate commands one for polylines and the other for lines, for some reason the way I was trying to have them in the same command was not working.
however I have ran into a small problem with the one for lines and that if you have two lines connected it will add two blocks to that location as it is both a start point and end point of a line.
would I add an if statement in the shared function for the line or the sub for the line to fix that problem?
the other thing is how would I tell it to only insert one block at the location?
below is all my code that I have so far and help will be
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.Windows
Public Class Class1
    'Gets the coordinates for the selected polylines
    Public Shared Function GetPolylineCoordinates(ByVal ent As Polyline) As Point3dCollection
        Dim pts As Point3dCollection = New Point3dCollection()
        Dim coord As Point3d
        Dim i As Integer = 0
        For i = 0 To ent.NumberOfVertices - 1
            coord = ent.GetPoint3dAt(i)
            pts.Add(coord)
        Next
        Return pts
    End Function
    'Specifies the command that is used for polylines
    <CommandMethod("plblk")> _
    Public Sub PolylineBlocks()
        'Selects the dwg file to be used as the block that is inserted
        Dim ofd As New OpenFileDialog(title:="Block Selection", defaultName:="", dialogName:="Block Selection", extension:="dwg", flags:=OpenFileDialog.OpenFileDialogFlags.NoFtpSites)
        ofd.ShowDialog()
        Dim doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim db As Database = doc.Database
        Dim ed As Editor = doc.Editor
        'Specifies the selection area
        Dim ppo As New PromptPointOptions(vbLf & "First Corner:")
        Dim ppr As PromptPointResult = ed.GetPoint(ppo)
        Dim pco As New PromptCornerOptions(vbLf & "Second Corner:", ppr.Value)
        Dim pcr As PromptPointResult = ed.GetCorner(pco)
        'Gets the start and end points of the selected polylines
        Dim p1 As Point3d = ppr.Value
        Dim p2 As Point3d = pcr.Value
        Dim pts As New Point3dCollection()
        pts.Add(p1)
        pts.Add(New Point3d(p2.X, p1.Y, 0))
        pts.Add(p2)
        pts.Add(New Point3d(p1.X, p2.Y, 0))
        'Creates a selection filter
        Dim tv As TypedValue() = New TypedValue() {New TypedValue(0, "LWPOLYLINE")}
        Dim flt As New SelectionFilter(tv)
        Dim res As PromptSelectionResult = ed.SelectCrossingPolygon(pts, flt)
        Using doclock As DocumentLock = doc.LockDocument
            Using tr As Transaction = db.TransactionManager.StartTransaction()
                Try
                    'Creates the specified block within the dwg
                    Dim bt As BlockTable
                    bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead)
                    Dim blkid As ObjectId
                    Dim ndb As Database = New Database(False, True)
                    ndb.ReadDwgFile(ofd.Filename, FileOpenMode.OpenForReadAndReadShare, True, Nothing)
                    Dim name As String = SymbolUtilityServices.GetBlockNameFromInsertPathName(ofd.Filename)
                    Dim btr As BlockTableRecord = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite)
                    blkid = db.Insert(name, ndb, True)
                    For Each selobj As SelectedObject In res.Value
                        Dim ent As Entity = tr.GetObject(selobj.ObjectId, OpenMode.ForRead)
                        'Gets the selected polylines
                        Dim pline As Polyline
                        pline = TryCast(ent, Polyline)
                        If pline IsNot Nothing Then
                            'Runs the shared function to get the coordinates of the polylines
                            Dim vertices As Point3dCollection = GetPolylineCoordinates(pline)
                            For i As Integer = 0 To vertices.Count - 1
                                'Adds the block to the polylines
                                Dim br As BlockReference = New BlockReference(vertices(i), blkid)
                                br.SetDatabaseDefaults()
                                btr.AppendEntity(br)
                                tr.AddNewlyCreatedDBObject(br, True)
                            Next
                        End If
                    Next
                    'Commits to the changes made
                    tr.Commit()
                Catch ex As Exception
                    ed.WriteMessage(ex.Message + vbLf + ex.StackTrace)
                End Try
            End Using
        End Using
    End Sub
    'Get the Coordinates for the selected lines
    Public Shared Function GetLineCoordinates(ByVal ent3 As Line) As Point3dCollection
        Dim pts3 As Point3dCollection = New Point3dCollection()
        Dim spt As Point3d
        Dim ept As Point3d
        spt = ent3.StartPoint
        ept = ent3.EndPoint
        pts3.Add(spt)
        pts3.Add(ept)
        Return pts3
    End Function
    'Specifies the command that is used for lines
    <CommandMethod("lnblk")> _
    Public Sub LineBlocks()
        ofd.ShowDialog()
        pts.Add(p1)
        pts.Add(p2)
        Dim tv As TypedValue() = New TypedValue() {New TypedValue(0, "LINE")}
                Try
                        'Gets the selected lines
                        Dim ln As Line
                        ln = TryCast(ent, Line)
                        If ln IsNot Nothing Then
                            'Run the shared function to get the coordinates of the lines
                            Dim vts As Point3dCollection = GetLineCoordinates(ln)
                            For i As Integer = 0 To vts.Count - 1
                                'Adds the block to the lines
                                Dim br3 As BlockReference = New BlockReference(vts(i), blkid)
                                br3.SetDatabaseDefaults()
                                btr.AppendEntity(br3)
                                tr.AddNewlyCreatedDBObject(br3, True)
                            Next
                        End If
                    Next
                    tr.Commit()
                End Try
            End Using
        End Using
    End Sub
End Class
greatly appreciated
Hallex
Message 16 of 35 (231 Views)
04-30-2012 09:59 AM in reply to: bkenyon13
Your subroutines is completely wrong, so I've removed them from code
See my poor explanation inside the code:
                pts.Add(coord)
            Next
            Return pts
        End Function
        <CommandMethod("instblk")> _
        Public Sub InsertBlocks()
            ofd.ShowDialog()
            pts.Add(p1)
            pts.Add(p2)
            '' this line is wrong, because of value types is with 0 code (or the same DxfCode.Start)
            ''Dim tv As TypedValue() = New TypedValue() {New TypedValue(0, "LWPOLYLINE"), New TypedValue(1, "POINT"), New TypedValue(1, "LINE")}
            '' this right:
            Dim tv As TypedValue() = New TypedValue() {New TypedValue(DxfCode.Start, "LWPOLYLINE,LINE,POINT")}
            ''OR:
            ' Dim tv As TypedValue() = New TypedValue() {New TypedValue(0, "LWPOLYLINE"), New TypedValue(0, "POINT"), New TypedValue(0, "LINE")}
            MsgBox(res.Value.Count)
                    Try
                        ndb.ReadDwgFile(ofd.FileName, FileOpenMode.OpenForReadAndReadShare, True, Nothing)
                        Dim name As String = SymbolUtilityServices.GetBlockNameFromInsertPathName(ofd.FileName)
                            Dim pt As DBPoint
                            pt = TryCast(ent, DBPoint) '<-- point entity is type of DBPoint in .NET
                            Dim ln As Line
                                Next
                            Else
                                If pt IsNot Nothing Then
                                    Dim verts As Point3d = pt.Position
                                    'Adds the block to the points
                                    Dim br2 As BlockReference = New BlockReference(verts, blkid)
                                    br2.SetDatabaseDefaults()
                                    btr.AppendEntity(br2)
                                    tr.AddNewlyCreatedDBObject(br2, True)
                                Else
                                        Dim vts As Point3dCollection = New Point3dCollection()
                                        vts.Add(ln.StartPoint)
                                        vts.Add(ln.EndPoint)
                                        Dim br3 As BlockReference = New BlockReference(vts(0), blkid)
                                        br3 = New BlockReference(vts(1), blkid)
                                    End If
                                End If
                            End If
                        Next
                        tr.Commit()
                    Catch ex As System.Exception
                    End Try
                End Using
            End Using
        End Sub
~'J'~
Active Contributor
bkenyon13
Message 17 of 35 (226 Views)
04-30-2012 11:17 AM in reply to: Hallex
Hallex I really do appreciate the time you have spend helping me with this and pretty much giving it to me even though you do not have to it is greatly appreciated.
This works perfect, again thank you.
the last thing that I have an issue trying to resolve with this is that as mentioned earlier when you have two lines where the end point of one meets the start point of another two blocks are added.  I think this could be resolved with an If statement but I am not sure exactly how to put it in.
I am goign to assume it would look something like this:
If ln.startpoint = ln.endpoint then
       (use only ln.startpoint or something) <---- I am not sure on this part of how to only insert one block
End If
Possibly even this:
If ln.startpoint.x = ln.endpoint.x and ln.startpon.y = ln.endpoint.y Then
      (Do Something)
End If
If you can just let me know if I am going in the right direction or not it would be greatly appreciated.
Hallex
Message 18 of 35 (223 Views)
04-30-2012 11:29 AM in reply to: bkenyon13
Okay I understand you want to use "chain-selection" for lines
to avoid of inserting the duplicate blocks
In this case you need to write separate Sub for that,
I will be try to show you that later
And also to compare points you may use comapring for all
coordinates with fuzz factor, e.g.:
if (math.Abs( p1.X-p2.X)< 0.0001) And _
(math.Abs( p1.Y-p2.Y)< 0.0001) And _
(math.Abs( p1.Z-p2.Z)< 0.0001) then
(do your job here)
else
end if
Hallex
Message 19 of 35 (220 Views)
04-30-2012 12:09 PM in reply to: Hallex
Here is simple code to gather line points,
hope you could be able to include it in your project
If not just let me know
        Public Shared Sub TestForLinePoints()
            Dim points As IDictionary(Of Point3d, Integer) = New Dictionary(Of Point3d, Integer)
            pts.Add(p1)
            pts.Add(p2)
            Dim tv As TypedValue() = New TypedValue() {New TypedValue(DxfCode.Start, "LINE")}
                    Try
                        Dim i As Integer = 1
                            Dim ln As Line = TryCast(ent, Line)
                            Dim ps As Point3d = ln.StartPoint
                            Dim pe As Point3d = ln.EndPoint
                            Try
                                points.Add(New KeyValuePair(Of Point3d, Integer)(ps, i))
                                i += 1
                                points.Add(New KeyValuePair(Of Point3d, Integer)(pe, i))
                                i += 1
                            Catch
                            End Try
                        Next
                        Dim inspts As Point3dCollection = New Point3dCollection
                        For Each kvp As KeyValuePair(Of Point3d, Integer) In points
                            inspts.Add(kvp.Key)
                        Next kvp
                        MsgBox(inspts.Count)
                        tr.Commit()
                    End Try
                End Using
            End Using
        End Sub
~'J'~
Active Contributor
bkenyon13
Message 20 of 35 (207 Views)
05-01-2012 07:07 AM in reply to: Hallex
Ok, so I look at the code that you gave me and tried a couple different things many of which did not work and some actually crashed AutoCAD.
Anyway below is the code that I have so far for the entire project.  I am have issues with the lines still in getting the block to actually insert.
I have gotten it to return a message box with values, but not insert a block on the lines.  You will probably say that how I have it was not what you intended, but I do not that it works to a point.
Thank you for your assistance
Public Class Class1
        ofd.ShowDialog()
        pts.Add(p1)
        pts.Add(p2)
                Try
                        'Gets the selected points
                        Dim pt As DBPoint
                        Dim ln As Line
                            Dim vertices As Point3dCollection = New Point3dCollection()
                            For i As Integer = 0 To pline.NumberOfVertices - 1
                                vertices.Add(pline.GetPoint3dAt(i))
                            Next
                        Else
                            Else
                                    Try
                                        i += 1
                                        i += 1
                                    Catch
                                    End Try
                                        inspts.Add(kvp.Key)
                                    Next kvp
                                    Dim br3 As BlockReference = New BlockReference(inspts(inspts.Count), blkid)
                                End If
                            End If
                        End If
                    Next
                    tr.Commit()
                End Try
            End Using
        End Using
    End Sub
End Class
