I would like to be able to collect information from a drawing via a sub-form and then insert a block with attributes (populated with collected info) into another open drawing. The insert operation would be launched from a button on my sub form.
Is this possible?
From the code below I attempted a test to simply select a point from another open drawing but was not successful. However, once I closed both forms the target drawing file is activated.
Thanks for any insight.
Chris
Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click Me.Hide() Dim docMgr As DocumentCollection = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager Dim i As Integer = 0 For Each doc As Document In docMgr Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(doc.Name) If i = 1 Then Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.DocumentActivationEnabled = True Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument = doc Dim ed As Editor = AcApp.Application.DocumentManager.MdiActiveDocument.Editor Dim dwg As Database = ed.Document.Database Dim prPointOptions As PromptPointOptions = New PromptPointOptions(ControlChars.NewLine & "pick") Dim prPointRes As PromptPointResult prPointOptions.AllowNone = True prPointRes = ed.GetPoint(prPointOptions) If prPointRes.Status = Autodesk.AutoCAD.EditorInput.PromptStatus.OK Then MsgBox(prPointRes.Value.X.ToString & " - " & prPointRes.Value.Y.ToString) End If End If i = i + 1 Next Me.Show() End Sub
Hi Chris,
try attached project
Hallex,
Maybe I am missing something but I don't see an attached project. Thanks.
