.NET
9 Kudos
Post 1 of 6
Insert Block From another File
1637 Views, 5 Replies
07-05-2012 02:28 AM
Hi Guys,
I am inserting a block from another file to the current drawing file.
I am using C#.Net.
My block gets added into the blocktable record of the current file, but while inserting the block using the "Block" command in AutoCAD its shows an error "The Existing Block has not been modified" I have attached a screenshot of the message i am getting.
I want to insert the block automatically to a user specified location.
How to resolve it ?
Thank You
Regards
Santosh
Below is code for how I have added blocks in VB.Net.
Note that in this case I added blocks to paperspace but you can change that easily.
Dim BlkFullPath As String
Dim currDwgDB As Database = myAcadApp.DocumentManager.MdiActiveDocument.Database
Try
' Awesome! this seaches the support paths for the file and if found returns the full path with file name.
BlkFullPath = HostApplicationServices.Current.FindFile(BlkName & ".dwg", currDwgDB, FindFileHint.Default)
Catch ex As Autodesk.AutoCAD.Runtime.Exception
MessageBox.Show(ex.Message & ": " & BlkName & ".dwg" & " not found in support paths.", "", MessageBoxButtons.OK, MessageBoxIcon.Exclamation)
Exit Sub
End Try
Using acLckDoc As DocumentLock = SheetDoc.LockDocument()
Using trx As Transaction = mySheetDB.TransactionManager.StartTransaction
Dim ObjId As ObjectId
Dim bt As BlockTable = mySheetDB.BlockTableId.GetObject(OpenMode.ForRead)
Dim btrMs As BlockTableRecord = bt(BlockTableRecord.PaperSpace).GetObject(OpenMode.ForWrite)
Using dbInsert As New Database(False, True)
dbInsert.ReadDwgFile(BlkFullPath, IO.FileShare.Read, True, "")
ObjId = mySheetDB.Insert(Path.GetFileNameWithoutExtension(BlkFullPath), dbInsert, True)
End Using
Dim BlkRef As New BlockReference(New Point3d(BlkX, BlkY, 0), ObjId)
btrMs.AppendEntity(BlkRef)
trx.AddNewlyCreatedDBObject(BlkRef, True)
' explode the block
BlkRef.ExplodeToOwnerSpace()
' when using ExplodeToOwnerSpace, if you dont do this then the block is retained in the drawing.
BlkRef.Erase(True)
trx.Commit()
End Using
End Using
Note that in this case Im adding to PaperSpace but you can change that.
Distinguished Contributor
0 Kudos
Post 2 of 6
Re: Insert Block From another File
07-05-2012 04:58 AM in reply to: santoshr0114
                        Try
                            Exit Sub
                        End Try
                                End Using
                                ' explode the block
                                BlkRef.Erase(True)
                                trx.Commit()
                            End Using
                        End Using
9 Kudos
Post 3 of 6
07-05-2012 05:28 AM in reply to: CommCorp
Hi CommCorp,
Will Try and post the result back
Thank You for your time
Regards
Santosh
9 Kudos
Post 4 of 6
07-05-2012 10:33 PM in reply to: santoshr0114
I actually was not inserting a block i was just adding it to the blocktable record, thats why i was getting an error,
When i looked at the last segment of your code i remembered what i missed.
I finshed the task sucessfully & just to inform you, i wrote the code in C#
Thank You for the solution
Regards
Santosh
Member
0 Kudos
Post 5 of 6
02-08-2013 02:17 PM in reply to: santoshr0114
Could I see that code? I've been struggling with this concept and have dropped it several times, resorting to Lisp.
9 Kudos
Post 6 of 6
02-09-2013 01:47 AM in reply to: nickmerchant
Find the below code, Alter as per your needs.
Find the code below, Alter as per your needs...
public void AddBlocktoDataBase()
Document doc = Application.DocumentManager.MdiActiveDocument;
using (Database OpenDb = new Database(false, true))
PromptStringOptions pStrOpts = new PromptStringOptions("Ask for the template like 1,2,3,4,etc");
pStrOpts.AllowSpaces = false;
PromptResult pStrRes = doc.Editor.GetString(pStrOpts);
if (pStrRes.Status != PromptStatus.OK)
return;
if (pStrRes.StringResult.Equals("1"))
OpenDb.ReadDwgFile("Template path here", System.IO.FileShare.ReadWrite, true, "");
blkname = "TPS-A1-Manufacturing-India";
ObjectIdCollection ids = new ObjectIdCollection();
using (Transaction tr = OpenDb.TransactionManager.StartTransaction())
//For example, Get the block by name "BlkName"
BlockTable bt;
bt = (BlockTable)tr.GetObject(OpenDb.BlockTableId, OpenMode.ForRead);
if (bt.Has(blockkname))
ids.Add(bt[blockname]);
tr.Commit();
//if found, add the block
if (ids.Count != 0)
//get the current drawing database
Database destdb = doc.Database;
IdMapping iMap = new IdMapping();
destdb.WblockCloneObjects(ids, destdb.BlockTableId, iMap, DuplicateRecordCloning.Ignore, false);
public void AddBlocktoModelSpace()
Database db = Application.DocumentManager.MdiActiveDocument.Database;
using (Transaction myT = db.TransactionManager.StartTransaction())
//Get the block definition "Check".
BlockTable bt = db.BlockTableId.GetObject(OpenMode.ForRead) as BlockTable;
BlockTableRecord blockDef = bt[blockname].GetObject(OpenMode.ForRead) as BlockTableRecord;
//Also open modelspace - we'll be adding our BlockReference to it
BlockTableRecord ms = bt[BlockTableRecord.ModelSpace].GetObject(OpenMode.ForWrite) as BlockTableRecord;
//Create new BlockReference, and link it to our block definition
using (BlockReference blockRef = new BlockReference(insertionpoint, blockDef.ObjectId))
//Add the block reference to modelspace
ms.AppendEntity(blockRef);
myT.AddNewlyCreatedDBObject(blockRef, true);
//Iterate block definition to find all non-constant
// AttributeDefinitions
foreach (ObjectId id in blockDef)
DBObject obj = id.GetObject(OpenMode.ForRead);
AttributeDefinition attDef = obj as AttributeDefinition;
if ((attDef != null) && (!attDef.Constant))
//This is a non-constant AttributeDefinition
//Create a new AttributeReference
using (AttributeReference attRef = new AttributeReference())
attRef.SetAttributeFromBlock(attDef, blockRef.BlockTransform);
//attRef.TextString = "Santosh";
//Add the AttributeReference to the BlockReference
blockRef.AttributeCollection.AppendAttribute(attRef);
myT.AddNewlyCreatedDBObject(attRef, true);
//Our work here is done
myT.Commit();
Regards
Santosh
