.NET
.NET
Member
0 Kudos
Post 1 of 2
Insert Bitmap File as OLE Object as an Embedded with C# on AutoCAD 2010
578 Views, 1 Replies
08-09-2012 02:04 AM
We want to import bitmap file as embedded on Autocad DWG drawing with programmatically [C#]. Is it possible. Bitmap file is a small barkod symbol. And manually is possible INSERTOBJ command. But we don' t have find any source .NET code resolution for this. There seems a OLE2FRAME class but i do not see any resolution.
Mehmet
ADN Support Specialist
100 Kudos
Post 2 of 2
Re: Insert Bitmap File as OLE Object as an Embedded with C# on AutoCAD 2010
08-13-2012 04:41 AM in reply to: kıeslowskı
Hi Mehmet,
It is not possible to create a OLE object throug API, but you can have a template drawing that has an ole object in it and insert it into another drawing. The path of the file can then be modified. There are several posts in this forum that have sample code for this.
Here is one such post. Try the "InsertOle" command from this thread :
http://forums.autodesk.com/t5/NET/How-to-embed-PDF-OLE-object/m-p/3330361/highlight/true#M27235
Balaji
Developer Technical Services
Autodesk Developer Network
