.NET
Infopoint properties (Mechanical)
0 REPLIES 0
Message 1 of 1
NovayaEra
452 Views, 0 Replies
Hi
I need to get properties (Name, Material, Mass ets.) from Infopoint in Autocad Mechanical 2013. I found this code to get infopoint and its works, but how to get property's values?
Dim acApp As AcadApplication = DirectCast(System.Runtime.InteropServices.Marshal.GetActiveObject("Autocad.Application.18"), AcadApplication)
Dim ed As Editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
        ed.WriteMessage("Select Infopoint:")
        Dim pso As New PromptSelectionOptions()
        pso.SinglePickInSpace = True
        Dim res As PromptSelectionResult = ed.GetSelection(pso)
        Dim SS As Autodesk.AutoCAD.EditorInput.SelectionSet = res.Value
        If SS Is Nothing Then
            Return
        If SS.Count < 1 Then
            Return
        If (SS(0)).ObjectId.ObjectClass.Name.Contains("AcmPartRef") Then
            ed.WriteMessage("Is an infopoint:")
0 REPLIES 0
”Boost
