.NET
Active Member
Atraeus
Message 1 of 7 (324 Views)
Incurring a fatal error while while running WPF plugin - But not while debugging
324 Views, 6 Replies
11-18-2013 05:18 AM
Good morning, All
    I am incurring a fatal error while i am running a plugin i have developed in .NET. I am using AutoCAD 2012 and .NET 4.0. Where the fatal error occurs is when i am filtering a list for specific colors and specific linetypes to populate a listbox with. I did a quite a bit of reading and the only thing i have found is ( in debug compiler is giving a little more memory space for said collection and when i run it in outside of debug it is not. )  Now i dont really understand how to fix this issue or can verify that it really is the issue. is there some type of setting i can change inside of autocad for debugging so it doesn't completely shut down? i need to atleast try to find out exactly why it is failing and what i can do to fix it.
I tried to upload a zip of my project bt it is to large, I will be more than happy to attach the files that i am able to.
Thanks in advance..
Trae
The issue was with WPF, I set the GroupName in XAML for a few radio buttons. Apparently it didn't like that. So by removing the GroupName the problem has been fixed.
Active Member
Atraeus
Message 2 of 7 (307 Views)
Re: Incurring a fatal error while while running WPF plugin - But not while debug
11-18-2013 06:53 AM in reply to: Atraeus
To add, I have found the error data when autocad crashed and it as follows:
Clr Data:
at System.Windows.Controls.RadioButton.UpdateRadioButtonGroup()
at System.Windows.Controls.RadioButton.OnChecked(RoutedEventArgs e)
at System.Windows.Controls.Primitives.ToggleButton.OnIsCheckedChanged(DependencyObject d, DependencyPropertyChangedEventArgs e)
at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args)
at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType)
at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal)
at System.Windows.DependencyObject.SetCurrentValueInternal(DependencyProperty dp, Object value)
at System.Windows.Controls.Primitives.ToggleButton.OnClick()
at System.Windows.Controls.Primitives.ButtonBase.OnMouseLeftButtonUp(MouseButtonEventArgs e)
at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
at System.Windows.Input.InputManager.ProcessStagingArea()
at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
Distinguished Mentor
BlackBox_
Message 3 of 7 (295 Views)
11-18-2013 08:32 AM in reply to: Atraeus
Hi Trae,
If you're not already doing so, add a Try/Catch block to your code... Example:
void FOO()
     Document doc = Application.DocumentManager.MdiActiveDocument;
     Editor ed = doc.Editor;
     try
          //<-- your code here
     catch (System.Exception ex)
          ed.WriteMessage("\n; error: {0}\n", ex.Message);
Also, you can always post your code directly in your post, using the 'Insert Code' button (next to the Paste from Word button).
Cheers
"Potential has a shelf life." - Margaret Atwood
Autodesk Exchange Apps ~ Autoloader ~ AutoCAD Security
AutoCAD® 2014, and Civil 3D® 2014 Certified Professional ~ Autodesk® Authorized Developer
Active Member
Atraeus
Message 4 of 7 (289 Views)
11-18-2013 08:45 AM in reply to: Atraeus
BlackBox_
Message 5 of 7 (283 Views)
11-18-2013 09:09 AM in reply to: Atraeus
Thanks for posting your solution, for others to find.
Cheers
Active Member
Atraeus
Message 6 of 7 (282 Views)
11-18-2013 09:09 AM in reply to: BlackBox_
BlackBox,
    I did implement a few try/catch statments, But the error would close autocad and not give me any feed back... I don't know why the GroupName property inside my XAML was making it fail like that.. I guess it reads from a different thread. Im not very clear on that. I am going to post the question to StackOverflow and see if i can get an answer.
Thanks for your help though.
Trae
BlackBox_
Message 7 of 7 (274 Views)
11-18-2013 09:34 AM in reply to: Atraeus
Atraeus wrote:
BlackBox,
Try adding a break point at your call to ed.WriteMessage()... Stepping through should also be something to consider when debugging.
Cheers
