.NET
Inconsistent Layout Renaming
3 REPLIES 3
642 Views, 3 Replies
I have written this code to check the name of the layouts and determine if the are to our company standard or not and if they are close enough to determine what they should be rename them. I create a drawing with severl differant layout names to test the code but I am getting inconsistent results. The drawing I created has 9 layouts named M2_03, M2_04, m3_01, m3_02, tm01_25, tm2.05, tm2.06a, TM2_01, and TM2_02A. It seems to be crashing on the tm2.06a but I can not figure out why.
Public Class StandFix
    <Autodesk.AutoCAD.Runtime.CommandMethod("StandFix")> _
    Public Sub StandardFixer()
        Dim ErrString As String = ""
        ErrString = ErrString & StandardizeLayoutNames()
        MsgBox(ErrString, MsgBoxStyle.OkOnly, "Non-Standard Entities Found")
    End Sub
    Private Function StandardizeLayoutNames()
        Dim LayoutErrs As String = ""
        Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
        Dim db As Database = acDoc.Database
        ' Get the layout dictionary of the current database
        Using acTrans As Transaction = db.TransactionManager.StartTransaction()
            Dim item As DBDictionaryEntry = Nothing
            Dim lays As DBDictionary = acTrans.GetObject(db.LayoutDictionaryId, OpenMode.ForWrite)
            For Each item In lays
                Dim acLayoutMgr As LayoutManager = LayoutManager.Current
                Dim objID As ObjectId = item.Value
                Dim acLayout As Layout = acTrans.GetObject(objID, OpenMode.ForWrite)
                Dim layoutname As String = acLayout.LayoutName
                If layoutname Like "T[MPF]#_##[A-Z]" Or layoutname Like "T[MPF]#_##" Or layoutname Like "[MPF]#_##[A-Z]" Or layoutname Like "[MPF]#_##" Or layoutname = "Model" Then
                    GoTo SkipLayout
                Else
                    ' MsgBox(layoutname)
                    Dim LayoutNameOld As String = layoutname
                    layoutname = layoutname.ToUpper()
                    If layoutname Like "T[MPF]#_##[A-Z]" Or layoutname Like "T[MPF]#_##" Or layoutname Like "[MPF]#_##[A-Z]" Or layoutname Like "[MPF]#_##" Then
                        LayoutErrs = LayoutErrs & "Layout: " & LayoutNameOld & " was renamed to " & layoutname & " to meet company standards" & vbCr
                    Else
                        If layoutname Like "T[MPF]#.##[A-Z]" Or layoutname Like "T[MPF]#.##" Or layoutname Like "[MPF]#.##[A-Z]" Or layoutname Like "[MPF]#.##" Then
                            layoutname = layoutname.Replace(".", "_")
                        Else
                            LayoutErrs = LayoutErrs & "Layout: " & LayoutNameOld & " is not a standard layout name" & vbCr
                    Try
                        acLayoutMgr.RenameLayout(LayoutNameOld, layoutname)
                    Catch ex As Exception
                        MsgBox(ex.Message)
                    End Try
SkipLayout:
            Next
            acTrans.Commit()
            acTrans.Dispose()
            acDoc.Editor.Regen()
        End Using
        Return LayoutErrs
    End Function
End Class
 Can anyone tell me why sometimes it work and checks all the layouts, but most of the time it only does some of the layouts.
Jeff
3 REPLIES 3
Ajilal.Vijayan
I tried your code by creating 9 layouts with these names.
It didnt crash on tm2.06a.
Thanks, I just create a new drawing with the same names hoping that maybe the old drawing was corrupt in some way, but I am still getting the same result. The first time I ran it is worked great and all the layouts renamed correctly. I then closed the drawing without saving and reopened it and ran the code again, this time it renamed all except for the tm2.03a. I have tried it several more time and 90% of the time is does not rename all the layouts. I am completely lost as to why it works sometimes and not other.
Virupaksha_aithal
Try below code. Code is same as yours, but puts the calling of RenameLayout API out of transaction.
        End Sub
            Dim list As New System.Collections.Generic.Dictionary(Of String, String)
                'Dim acLayoutMgr As LayoutManager = LayoutManager.Current
                Dim lays As DBDictionary = acTrans.GetObject(db.LayoutDictionaryId, OpenMode.ForRead)
                    Dim acLayout As Layout = acTrans.GetObject(objID, OpenMode.ForRead)
                        'do anything..
                    Else
                        Else
                            Else
                        Try
                            list.Add(LayoutNameOld, layoutname)
                            ' acLayoutMgr.RenameLayout(LayoutNameOld, layoutname)
                        Catch ex As System.Exception
                            MsgBox(ex.Message)
                        End Try
                Next
                acTrans.Commit()
                acTrans.Dispose()
            End Using
            For Each pair In list
                acLayoutMgr.RenameLayout(pair.Key, pair.Value)
            Next
            Return LayoutErrs
        End Function
Virupaksha Aithal KM
Developer Technical Services
Autodesk Developer Network
”Boost
