.NET
.NET
Active Contributor
0 Kudos
Post 1 of 7
Import Triangle from excel using modal form of c#.net.
514 Views, 6 Replies
02-07-2014 12:12 AM
Hi
I have an excel file with a column containing lower width,upper width and height like follows:
Row 1  point
Row 2 10
Row 3 7
I am looking for a .Net code that can read each row cell and draw the triangle automatically in AutoCAD window. I am having a bout 100 rows  and hence I prefer that the code will display all triangle and another polygons at once in AutoCAD window and not draw them one by one.
I want to open excel file from user read data from excel show it in textbox on form and when user press draw button triangle should be drawn. I wish to have a .Net code to allow batch Trianle drawing instead.
I am new in programming. Please help me as earliest.
Thanks a lot for any assistance
Hi ,
With below code you can start your project.
 <CommandMethod("TRA")> Public Sub TriangleDraw()
'declare the form to open
Dim frmTriangle As TestTraingle = Nothing
If frmTriangle Is Nothing Then
frmTriangle = New TestTraingle()
ElseIf frmTriangle.IsDisposed Then
End If
'show the form
Application.ShowModelessDialog(Application.MainWindow.Handle, frmTriangle, False)
End Sub
Imports System.IO
Imports Microsoft.Office.Interop
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.DatabaseServices
Public Class TestTraingle
Dim tra_upperwidth As String = Nothing
Dim tra_lowerwidth As String = Nothing
Dim tra_height As String = Nothing
Private Sub TestTraingle_Load(sender As System.Object, e As System.EventArgs) Handles MyBase.Load
Try
'place the excelfile path
Dim excelFilePath = "Place your excel file path"
If File.Exists(excelFilePath) Then
Call READEXCELFILE(excelFilePath)
End If
TextBox1.Text = tra_upperwidth
TextBox2.Text = tra_lowerwidth
TextBox3.Text = tra_height
Catch ex As System.Exception
MsgBox(ex.Message)
End Try
End Sub
Private Sub Button1_Click(sender As System.Object, e As System.EventArgs) Handles Button1.Click
'get current document
Dim doc As Document = Application.DocumentManager.MdiActiveDocument
Dim db As Database = doc.Database
'lock document as using modeless form
Using docLock As DocumentLock = doc.LockDocument
Using tx As Transaction = db.TransactionManager.StartTransaction()
'open blocktable
Dim bt As BlockTable = tx.GetObject(db.BlockTableId, OpenMode.ForRead)
'open model space for write
Dim ms As BlockTableRecord = tx.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
'converte text value
Dim uWidth As Double = CDbl(TextBox1.Text)
Dim base As Double = CDbl(TextBox2.Text)
Dim tHeight As Double = CDbl(TextBox3.Text)
Dim pt1 As Point2d = New Point2d(0, 0)
Dim pt2 As Point2d = New Point2d(base, 0)
Dim pt3 As Point2d = New Point2d(base / 2, tHeight)
'draw traiangle
Dim tra As Polyline = New Polyline()
tra.AddVertexAt(0, pt1, 0, 0, 0)
tra.AddVertexAt(1, pt2, 0, 0, 0)
tra.AddVertexAt(2, pt3, 0, 0, 0)
tra.Closed = True
'add triangle in model space
ms.AppendEntity(tra)
tx.AddNewlyCreatedDBObject(tra, True)
tx.Commit()
End Using
End Using
End Sub
Public Sub READEXCELFILE(filePath As String)
'read excel file
Try
Dim xlApp As New Excel.Application
Dim xlWorkBook As Excel.Workbook = xlApp.Workbooks.Open(filePath)
Dim xlSheet As Excel.Worksheet = xlWorkBook.Worksheets("Sheet1")
'get all cells value
tra_upperwidth = xlSheet.Cells(1, 2).Value
tra_lowerwidth = xlSheet.Cells(2, 2).Value
tra_height = xlSheet.Cells(3, 2).Value
xlWorkBook.Close()
'quit excel application
xlApp.Quit()
'relaese excel object
ReleaseExcelObject(xlWorkBook)
ReleaseExcelObject(xlApp)
MsgBox(ex.Message)
End Try
End Sub
Public Shared Sub ReleaseExcelObject(obj As Object)
'release excel object after finishing
Try
System.Runtime.InteropServices.Marshal.ReleaseComObject(obj)
obj = Nothing
Catch ex As Autodesk.AutoCAD.Runtime.Exception
obj = Nothing
Finally
GC.Collect()
End Try
End Sub
End Class
30 Kudos
Post 2 of 7
Re: Import Triangle from excel using modal form of c#.net.
02-07-2014 12:31 AM in reply to: bvyas89
HI, I can not open your drawing file as I am using ACAD2011. Can you save the file in 2011 Format? or Can you explain lower width and upper width? I did not get what you mean by lower width and upper width. I think with lower width you mean the base of a triangle. I did not get the meaning of upper width. Where do you want to draw the triangle? In your description you have stated that row 1 is Point but in the Excel file row 1 is upper width which is also confusing to me. Kindly make clear so that I can help you.
Active Contributor
0 Kudos
Post 3 of 7
02-07-2014 01:01 AM in reply to: mzakiralam
hi,
Please find Attach file. I am working in civil company.  I am intending to Draw tower from user input in excel. this  exercise wiil be beneficial to me to  complete my task. Lower width is base of triangle and height is height of triangle. Upper Width is not applicable here.
Actually i think that if i consider one starting point i can draw base line of traingle from  lower width as i got secon poin. and from base line i can calculate mid point that x and from height y for upper point then it is posssible to me to draw triangle..
hope you can help me for this.
thank you so much for your prompt reply.
Active Contributor
0 Kudos
Post 4 of 7
02-07-2014 01:39 AM in reply to: bvyas89
hope this drawing will clear what i exactly  mean.
30 Kudos
Post 5 of 7
02-07-2014 07:04 AM in reply to: bvyas89
Hi ,
        End If
        'show the form
    End Sub
Imports System.IO
        Try
            End If
            MsgBox(ex.Message)
        End Try
    End Sub
                'open blocktable
                'draw traiangle
                tra.Closed = True
                tx.Commit()
            End Using
        End Using
    End Sub
        'read excel file
        Try
            xlWorkBook.Close()
            xlApp.Quit()
            MsgBox(ex.Message)
        End Try
    End Sub
        Try
            obj = Nothing
            obj = Nothing
        Finally
            GC.Collect()
        End Try
    End Sub
End Class
30 Kudos
Post 6 of 7
02-07-2014 07:09 AM in reply to: bvyas89
Active Contributor
0 Kudos
Post 7 of 7
02-10-2014 01:22 AM in reply to: mzakiralam
Thank you so much Mzakiralam... Its work fine ....
