.NET
Import Page Setups
1 REPLY 1
BrentBurgess1980
267 Views, 1 Reply
Import Page Setups
I assume there is a way to import page setups from an external drawing into the current drawing. I have not been able to find anything regarding this at all on the net. Am I searching using the wrong keywords?
Can somebody let me know where I can find this information?
Brent
1 REPLY 1
in reply to: BrentBurgess1980
Obviously, I know this is a C# forum. However, I usually try to avoid reinventing the wheel. Check the lsp forum for discussion about this topic. I've attached a routine (Daps) that does this. I specify a template on the network that has all of our page setups in it, and then call daps from our enterprise mnl, so that the page setups get loaded in whenever a drawing opens.
While it's not C#, it is an easy implementation to a common CAD problem.
Change the .txt to a .lsp
”Boost
