.NET
Import of external data into AutoCAD
2 REPLIES 2
457 Views, 2 Replies
could someone explain me, how I can attach some external data to an AutoCAD object. I found on the internet the object data solution for AutoCAD MAP 3D, but my boss meant, I should find a possibility to import data into AutoCAD without MAP 3D.
Could you tell me, how it should work/or give me some tutorial links?
With kind regards,
NikWach
2 REPLIES 2
Matti72
Each DBObject in Autocad has an ExtensionDictionary property. You can use this Dictionary to store extended data for each object.
The Dictionary is a DBDictionary. There you can store your data with a unique key and access it later on.
CADbloke
in reply to: Matti72
Be aware that if you ATTSYNC a block it erases all those block instances' extended data. See: http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%202010%20User%20Documentation/index.html?url=WS1a91938... and other such friendly URLs.
working on all sorts of things including www.tvCAD.tv & www.CADreplace.com
”Boost
