Hi
was thinking about import OSM into Mysql from this plase http://www.diva-gis.org/gdata
buildings.shp
landuse.shp
points.shp
roads.shp
Have been search the forum about sample how to import into autocad with VB.NET from the database
do anyone know about sample what I can use
Regards
Sgear
You will need map 3d or civil 3d. There are tutorials here:
Hi
I am using Autocad map 3d in my work
http://forums.autodesk.com/t5/NET/import-from-Mysql-into-Mtext/m-p/5081834/highlight/true#M40898
in this url I was learning how to get Mtext into Autocad from Mysql I am finish with it , it is fast and easy to use just query the postcode and insert
but know I want to learn how to get the rest of the map 🙂 from MYSQL
import ESRI shape files or use FDO I have try it and thing it is slow and annoying I want to have more control what I get from the Map like use
query in VB.NET from database
Regards
Sgear
