.NET
import Excel layer list to AutoCAD
2 REPLIES 2
wang890
4053 Views, 2 Replies
hi everyone
has anybody made a program and can share it here? both source code in vb.net or dll file is fine.
thank you very much.
Stantec
Dell Precision 5530, Prism M320PU, C3D 14/17/19
2 REPLIES 2
Hallex
in reply to: wang890
Take a look ath this example
http://through-the-interface.typepad.com/through_the_interface/2007/08/creating-an-aut.html
Hi there,
I've created a simple project to read the layernames from excel and add these to the drawing.
It's written in c# But there are enough converters around. Project is attached including an excel 2007 file.
Good luck,
Irvin
using System;
using System.Text;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Excel = Microsoft.Office.Interop.Excel;
namespace CreateLayerFromExcel
    public class Layer
        [CommandMethod("CreatLayersFromExcel")]
        public void CreatLayersFromExcel()
            Excel.Application xlApp;
            Excel.Workbook xlWorkBook;
            Excel.Worksheet xlWorkSheet;
            Excel.Range range;
            string str;
            int rCnt = 0;
            int cCnt = 0;
            xlApp = new Excel.ApplicationClass();
            xlWorkBook = xlApp.Workbooks.Open("c:\\temp\\test.xlsx", 0, true, 5, "", "", true, Microsoft.Office.Interop.Excel.XlPlatform.xlWindows, "\t", false, false, 0, true, 1, 0);
            xlWorkSheet = (Excel.Worksheet)xlWorkBook.Worksheets.get_Item(1);
            range = xlWorkSheet.UsedRange;
            for (rCnt = 1; rCnt <= range.Rows.Count; rCnt++)
                for (cCnt = 1; cCnt <= range.Columns.Count; cCnt++)
                    str = (string)(range.Cells[rCnt, cCnt] as Excel.Range).Value2;
                    CreateLayer(str);
                    System.Windows.Forms.MessageBox.Show(str + " created!");
            xlWorkBook.Close(true, null, null);
            xlApp.Quit();
            releaseObject(xlWorkSheet);
            releaseObject(xlWorkBook);
            releaseObject(xlApp);
        private void releaseObject(object obj)
            try
                System.Runtime.InteropServices.Marshal.ReleaseComObject(obj);
                obj = null;
            catch (System.Exception ex)
                obj = null;
                System.Windows.Forms.MessageBox.Show("Unable to release the Object " + ex.ToString());
            finally
                GC.Collect();
        private void CreateLayer(string layerName)
            ObjectId layerId;
            Database db = HostApplicationServices.WorkingDatabase;
            using (Transaction trans = db.TransactionManager.StartTransaction())
                LayerTable lt = (LayerTable)trans.GetObject(db.LayerTableId, OpenMode.ForRead);
                if (lt.Has(layerName))
                    layerId = lt[layerName];
                else
                    LayerTableRecord ltr = new LayerTableRecord();
                    ltr.Name = layerName;
                    //ltr.Color = Color.FromColorIndex(ColorMethod.ByAci, 2);
                    lt.UpgradeOpen();
                    layerId = lt.Add(ltr);
                    trans.AddNewlyCreatedDBObject(ltr, true);
                trans.Commit();
”Boost
