.NET
Keith.Brown
Message 11 of 13 (199 Views)
Re: Imperial input from user in Foot Inch .
01-22-2012 07:23 AM in reply to: Keith.Brown
Ok, I think I figured it out.  the integer required should be the denominator of the fraction of the precision required.  For example, 1/4" precision would require the integer 4 and 1/256" precision would require the integer 256.
If you want to use the drawing units,   just use:
Autodesk.AutoCAD.Runtime.Converter.DistanceToStrin​g(Dist as double) as string
Keith Brown AutoCAD MEP BLOG | RSS Feed
AutoCAD MEP 2014 | Revit 2014 | EastCoast CAD/CAM V6.1 | Visual Studio 2013
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate. Thank you!
Distinguished Contributor
HJohn1
Message 12 of 13 (188 Views)
01-22-2012 08:58 PM in reply to: JanetDavidson
I had a similar situation once.  I found that the best solution was using Regular Expressions.  That way you can parse whatever the user puts in your text box.  In my case I restricted the units to inches, but they where free to write some like 10'-1 5/16", 5/32", 10" or 8.75".
Active Contributor
RichardCammeray
Message 13 of 13 (115 Views)
04-17-2013 03:31 PM in reply to: Keith.Brown
Recently I used Converter.DistanceToString method and I would like to clarify two points for others.
1) Precision is integer from 0 to 8 (LUPREC equivalent). E.g. 1/4" is 2.
2) This method return value affected by AutoCAD variable DIMZIN. This variable controls suppression of zero. You have to temporary change it to your needs and then revers it back.
