.NET
IGES export
2 REPLIES 2
ivo.zagar
700 Views, 2 Replies
IGES export
Is it possible to export IGES files from .NET or lisp?
Regards, Ivo
2 REPLIES 2
adam.nagy
in reply to: ivo.zagar
HI there,
Here is a code that may need to be changed depending on which AutoCAD version you are using:
<code>
; Lisp routine for IGESOUT
(defun c:run_igesout()
(setvar "cmddia" 0)
(setvar "filedia" 0)
(arxload "igesout.arx")
(igesout "test.dwg" "")
(arxunload "igesout.arx")
</code>
In AutoCAD 2012 use "AcIges.arx" instead of "igesout.arx" and "igesexport" instead of "igesout"
Cheers,
Adam Nagy
Autodesk Developer Network
Adam Nagy
Autodesk Platform Services
webcom2007
in reply to: adam.nagy
Dear Mr Adam
  Thanks for this lisp routine. I want to auto mate following tasks
1) opening multiple cad files ( lets say 'AA.cad'  to 'FF.cad') which are kept in a specified folder named 'test'
2)open file 'AA.cad'
3)stepout the 3D model contained in cad file. --to the same folder named "test'
4)close the 'AA.cad'.
5) open next cad file and repeat till all cad files are converted.
can you help with this with a lisp routine. we have  one month trial version Autocad16.
Tags (1)
”Boost
