.NET
Active Member
0 Kudos
Post 1 of 2
IGES export
312 Views, 1 Replies
02-21-2012 12:30 PM
Is it possible to export IGES files from .NET or lisp?
Regards, Ivo
ADN Support Specialist
103 Kudos
Post 2 of 2
Re: IGES export
02-21-2012 06:14 PM in reply to: ivo.zagar
HI there,
Here is a code that may need to be changed depending on which AutoCAD version you are using:
<code>
; Lisp routine for IGESOUT
(defun c:run_igesout()
(setvar "cmddia" 0)
(setvar "filedia" 0)
(arxload "igesout.arx")
(igesout "test.dwg" "")
(arxunload "igesout.arx")
</code>
In AutoCAD 2012 use "AcIges.arx" instead of "igesout.arx" and "igesexport" instead of "igesout"
Cheers,
Adam Nagy
Autodesk Developer Network
Adam Nagy
Developer Technical Services
