.NET
.NET
wein3967
Message 1 of 3 (401 Views)
Identifying Object Type String for Selection Set Filter
401 Views, 2 Replies
05-25-2013 04:52 PM
I am currently running AutoCAD 2011. I have a specific problem, but I am also looking for a solution to the general issue as well.
Specifically, I am trying to identify the object type of a Polyface Mesh for use in a Selection Set filter. For example, a 3D solid will return "Solid3D" from the GetType method, but for the selection set filter I have to use the string "3DSOLID" in order for it to filter correctly. The GetType method for my Polyface Mesh returns PolyFaceMesh, which does not work for my Selection Set filter.
In general, I'd like to have a code that will just tell me what the proper type string is for use in filters. I frequently use the following code (copied from a developer's post) to help me out, but I still can't find the method that will return the the information I am looking for here.
Public Class WhoAmI
        ' Must have UsePickSet specified
        <CommandMethod("WAI", _
          (CommandFlags.UsePickSet _
            Or CommandFlags.Redraw _
            Or CommandFlags.Modal))> _
        Public Shared Sub ObjectProperties()
            Dim doc As Document = _
              Application.DocumentManager.MdiActiveDocument
            Dim ed As Editor = doc.Editor
            Try
                Dim selectionRes As PromptSelectionResult
                selectionRes = ed.SelectImplied
                ' If there's no pickfirst set available...
                If (selectionRes.Status = PromptStatus.Error) Then
                    ' ... ask the user to select entities
                    Dim selectionOpts As PromptSelectionOptions
                    selectionOpts = New PromptSelectionOptions
                    selectionOpts.MessageForAdding = _
                      vbLf & "Select objects to list: "
                    selectionRes = ed.GetSelection(selectionOpts)
                Else
                    ' If there was a pickfirst set, clear it
                    'ed.SetImpliedSelection(Nothing)
                End If
                ' If the user has not cancelled...
                If (selectionRes.Status = PromptStatus.OK) Then
                    ' ... take the selected objects one by one
                    Dim tr As Transaction = _
                      doc.TransactionManager.StartTransaction
                    Try
                        Dim objIds() As ObjectId = _
                          selectionRes.Value.GetObjectIds
                        For Each objId As ObjectId In objIds
                            Dim obj As Object = _
                              tr.GetObject(objId, OpenMode.ForRead)
                            Dim ent As Entity = _
                              CType(obj, Entity)
                            Stop
                            'MsgBox(ent.ColorIndex)
                            ' This time access the properties directly
                            ed.WriteMessage(vbLf + "Type:        " + ent.GetType().ToString)
                            ed.WriteMessage(vbLf + "  ObjectID:    " + ent.ObjectId().ToString)
                            ed.WriteMessage(vbLf + "  Handle:    " + ent.Handle().ToString)
                            ed.WriteMessage(vbLf + "  Layer:      " + ent.Layer().ToString)
                            ed.WriteMessage(vbLf + "  Linetype:  " + ent.Linetype().ToString)
                            ed.WriteMessage(vbLf + "  Lineweight: " + ent.LineWeight().ToString)
                            ed.WriteMessage(vbLf + "  ColorIndex: " + ent.ColorIndex().ToString)
                            ed.WriteMessage(vbLf + "  Color:      " + ent.Color().ToString)
                            ' Let's do a bit more for circles...
                            If TypeOf (obj) Is Circle Then
                                Dim circ As Circle = CType(obj, Circle)
                                ed.WriteMessage(vbLf + "  Center:  " + _
                                  circ.Center.ToString)
                                ed.WriteMessage(vbLf + "  Radius:  " + _
                                  circ.Radius.ToString)
                            End If
                            obj.Dispose()
                        Next
                        ' Although no changes were made, use Commit()
                        ' as this is much quicker than rolling back
                        tr.Commit()
                    Catch ex As Autodesk.AutoCAD.Runtime.Exception
                        ed.WriteMessage(ex.Message)
                        tr.Abort()
                    End Try
                End If
            End Try
        End Sub
  Here is the code I use for implementing the Selection Set filter. The FilterString is the value I am looking for.
Private Function GetSelectionSet(ByVal FilterString As String) As ObjectId()
            '' Get the current document editor
            Dim acDocEd As Editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
            '' Create a TypedValue array to define the filter criteria
            Dim acTypValAr(0) As TypedValue
            acTypValAr.SetValue(New TypedValue(DxfCode.Start, FilterString), 0)
            '' Assign the filter criteria to a SelectionFilter object
            Dim acSelFtr As SelectionFilter = New SelectionFilter(acTypValAr)
            '' Request for objects to be selected in the drawing area
            Dim acSSPrompt As PromptSelectionResult
            acSSPrompt = acDocEd.GetSelection(acSelFtr)
            '' If the prompt status is OK, objects were selected
            If acSSPrompt.Status = PromptStatus.OK Then
                Dim acSSet As SelectionSet = acSSPrompt.Value
                'Dim idarray As ObjectId() = acSSet.GetObjectIds()
                Return acSSet.GetObjectIds()
            End If
        End Function
 Thanks a bunch.
norman.yuan
Message 2 of 3 (387 Views)
Re: Identifying Object Type String for Selection Set Filter
05-25-2013 09:43 PM in reply to: wein3967
ObjectId.ObjectClass.DxfName is what yuo are looking for.
For example, if you get the ObjectId of a BlockReference, its ObjectClass.DxfName property will have value "INSERT", which can be used as selectionset filter.
wein3967
Message 3 of 3 (362 Views)
05-26-2013 08:09 AM in reply to: norman.yuan
Norman,
Thanks. Just what I was looking for!
