.NET
identify the presence of the block in a particular layout
2 REPLIES 2
638 Views, 2 Replies
I have to insert a block in a paerspace layout if it is not already present in that layout.
I tried the following function to identify the presence of the block.
But it returns true even if the block is not present in the particular layout but is present in another layout.
private bool checkBlockPresence()
            try
                Autodesk.AutoCAD.EditorInput.Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
                Autodesk.AutoCAD.DatabaseServices.TypedValue[] acTypValAr;
                acTypValAr = new Autodesk.AutoCAD.DatabaseServices.TypedValue[1];
                //acTypValAr.SetValue(new Autodesk.AutoCAD.DatabaseServices.TypedValue((int)Autodesk.AutoCAD.DatabaseServices.DxfCode.Start, "INSERT"), 0);
                acTypValAr.SetValue(new Autodesk.AutoCAD.DatabaseServices.TypedValue((int)Autodesk.AutoCAD.DatabaseServices.DxfCode.BlockName, "BPC_PrjDrg_Logo"), 0);
                Autodesk.AutoCAD.EditorInput.SelectionFilter sf = new Autodesk.AutoCAD.EditorInput.SelectionFilter(acTypValAr);
                Autodesk.AutoCAD.EditorInput.PromptSelectionResult selPrompt = ed.SelectAll(sf);
                if (selPrompt.Status == Autodesk.AutoCAD.EditorInput.PromptStatus.OK)
                    Autodesk.AutoCAD.EditorInput.SelectionSet acSet = selPrompt.Value;
                    if (acSet.Count > 0)
                        return true;
                    else
                        return false;
            catch (Exception ex)
                System.Windows.Forms.MessageBox.Show("Error while checkBlockPresence: Type" + ex.GetType() + "  Message:" + ex.Message);
                return false;
Also I am using the following function to make the particular layout active before calling the above function.
        public void SwitchTo(string Layout)
            Autodesk.AutoCAD.ApplicationServices.Document acDoc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Autodesk.AutoCAD.DatabaseServices.Database acCurDb = acDoc.Database;
            using (Autodesk.AutoCAD.ApplicationServices.DocumentLock doclock = acDoc.LockDocument())
                using (Autodesk.AutoCAD.DatabaseServices.Transaction acTrans = acCurDb.TransactionManager.StartTransaction())
                    try
                        Autodesk.AutoCAD.DatabaseServices.LayoutManager acLayoutMgr;
                        acLayoutMgr = Autodesk.AutoCAD.DatabaseServices.LayoutManager.Current;
                        acLayoutMgr.CurrentLayout = Layout;
                        //  System.Windows.Forms.MessageBox.Show("Current Layout = " + acLayoutMgr.CurrentLayout);
                        acTrans.Commit();
                    catch (Autodesk.AutoCAD.Runtime.Exception ex)
                        Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("Exception while changing to " + Layout + "\n Error:" + ex.Message);
So my code is similer to
SwithTo("A3")
if(checkBlockPresence() == false)  // this always returns true.
Shijith
2 REPLIES 2
Alexander.Rivilis
private bool checkBlockPresence(string BlockName, string LayoutName)
  try {
    acTypValAr = new Autodesk.AutoCAD.DatabaseServices.TypedValue[2];
    acTypValAr.SetValue(new Autodesk.AutoCAD.DatabaseServices.TypedValue((int)Autodesk.AutoCAD.DatabaseServices.DxfCode.BlockName, BlockName), 0);
    acTypValAr.SetValue(new Autodesk.AutoCAD.DatabaseServices.TypedValue((int)Autodesk.AutoCAD.DatabaseServices.DxfCode.LayoutName, LayoutName), 1);
    if (selPrompt.Status == Autodesk.AutoCAD.EditorInput.PromptStatus.OK) {
      if (acSet.Count > 0) return true;
                else       return false;
  catch (Exception ex) {
  return false;
I hope this code help you.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
in reply to: Alexander.Rivilis
Thank you so much for the reply. It worked perfectly. I didn't thought about placing layout in filter itself.
Regrads,
Shijith.
”Boost
