.NET
Identify features that have been processed by an UNDO/REDO operation
4 REPLIES 4
diordonez
915 Views, 4 Replies
I have an application to maintain water/sewer networks in AutoCAD and a Relational Database.
How can I detect when the user performs UNDO or REDO, and identify what features have been affected by this operation, since I need to maintain integrity between CAD and Database.
That means if the user UNDO a water pipe creation I need to delete programmatically the same pipe in the database.
If the user REDO the pipe creation I need to recreate the pipe in the database.
4 REPLIES 4
Hallex
in reply to: diordonez
My guess is create primary key as Handle of pipe,
then you would be able delete it from SQL /Access Database
using DatagridView or other control
Just an idea
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
diordonez
Thanks for your suggestion.
My real question is: How can I know that a pipe has been deleted as a consequence of the UNDO operation ? OR, how can I know that a pipe has been re-created as a consequence of the REDO operation.
Hallex
I think you may use doc.Database object events
Database db = doc.Database;
db.ObjectAppended+=...
db.ObjectErased+=...
db.ObjectModified+=...
db.ObjectReappended+=...
db.ObjectUnappended+=...
In every event you can perform operation that you need
to link with SQL / Access Database
Not tested actually,j ust a guess, sorry
diordonez
Thanks for the suggestion.
I'll test it and I'll let you know the results.
Regards.
Diego
”Boost
