.NET
1 Kudo
Post 1 of 15
Iam still failure in .net
350 Views, 14 Replies
02-26-2013 12:53 AM
see attatch
amremad_world wrote:
!!!! ObjectARX 2013 doesn't work with early version !!!!!!
Of course! You read casually (or not read?) what was write for you. wrote for you:
Use the ARX SDK with the same name as the AutoCAD version that the appliaction will run on. Also check the .NET framework supported by the AutoCAD version:
AutoCAD 2011, ARX SDK 2011, .Net 2.0 or 3.5
AutoCAD 2012, ARX SDK 2012, .Net 4.0
AutoCAD 2013, ARX SDK 2013, .Net 4.0
so i think i can use  ARX SDK 2013 with AutoCAD 2012 & AutoCAD 2013
and i think i can use  ARX SDK 2012 with AutoCAD 2012 & AutoCAD 2013
cause it's have the same verison of .net??
Moderator
277 Kudos
Post 2 of 15
Re: Iam still failure in .net
02-26-2013 02:49 AM in reply to: Amremad
1. What AutoCAD version are you using?
2. Why you add Interops from two version (2011 and 2013) ?
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
1 Kudo
Post 3 of 15
02-26-2013 02:51 AM in reply to: Alexander.Rivilis
2010 and 2013
Moderator
277 Kudos
Post 4 of 15
02-26-2013 02:55 AM in reply to: Amremad
I do not think you can write one application at once for two versions of AutoCAD. So decide which version of AutoCAD you work. In any case, ObjectARX SDK 2011 is not suitable for AutoCAD 2010 - AutoCAD 2010 need to ObjectARX SDK 2010.
1 Kudo
Post 5 of 15
02-26-2013 03:01 AM in reply to: Alexander.Rivilis
Moderator
277 Kudos
Post 6 of 15
02-26-2013 03:07 AM in reply to: Amremad
1 Kudo
Post 7 of 15
02-26-2013 03:10 AM in reply to: Alexander.Rivilis
:smileysad:
in my company we use diffrenet version .. so i must create diffrenet dll to every version??
but it will be hard to create code three time or 4 , 5  :smileyhappy: :smileyhappy: :smileyhappy:
1 Kudo
Post 8 of 15
02-26-2013 03:11 AM in reply to: Alexander.Rivilis
Moderator
277 Kudos
Post 9 of 15
02-26-2013 03:15 AM in reply to: Amremad
It may be same source code (.vb - files) but different project/solution which produce different dll-files. Other way is most hard - using Reflection. As you are beginner I can not recommend to use reflection in order to produce  one dll-file which can work in any AutoCAD version.
1 Kudo
Post 10 of 15
02-26-2013 03:16 AM in reply to: Amremad
sorry i have a big confflict in my mind with this techonology :smileyhappy:
i think there is why to check version in class that i will do like
if Autocad2013 then
elseif AutoCAD2010 then
end if
