.NET
I want to read data from a DWG excel file using C sharp
1 REPLY 1
808 Views, 1 Reply
example code:
[CommandMethod("Test")]
public static void TestMethod()
    Document doc = Application.DocumentManager.MdiActiveDocument;
    Editor ed = doc.Editor;
    Database db = doc.Database;
    using (Transaction Tx = db.TransactionManager.StartTransaction())
        BlockTableRecord bt = Tx.GetObject(db.CurrentSpaceId, OpenMode.ForRead) as BlockTableRecord;
        foreach (ObjectId id in bt)
            if (id.ObjectClass.Name != "AcDbOle2Frame")
                continue;
            Ole2Frame oleFrame = Tx.GetObject(id, OpenMode.ForRead) as Ole2Frame;
            if (! oleFrame.IsLinked)
                Microsoft.Office.Interop.Excel.Workbook wb = oleFrame.OleObject as Microsoft.Office.Interop.Excel.Workbook;
                Microsoft.Office.Interop.Excel.Worksheet ws = wb.ActiveSheet;
                Microsoft.Office.Interop.Excel.Range range = ws.UsedRange;
                for (int row = 1; row <= 15; row++)
                    for (int col = 1; col <= range.Columns.Count; col++)
                        ed.WriteMessage(String.Format("{0}{1}{2}-{3}", Environment.NewLine, row, col, Convert.ToString((range.Cells[row, col] as Microsoft.Office.Interop.Excel.Range).Value2)));
1-autocad program will be closed
2-be selected within the file path c sharp example: csharp.jpg
3-I want to read data from a DWG excel file using C#. examples: dwgfile.jpg and drawing1.dwg
4-I want to list here DataGridView data
5-c sharp winform .net 4.0
Can you help me?
1 REPLY 1
fenton.webb
I recommend you cut down this post into smaller posts
Fenton Webb
AutoCAD Engineering
”Boost
