.NET
.NET
Active Contributor
dancalgary
Message 1 of 4 (220 Views)
I have a line and a circle I want to get the intersection of both
220 Views, 3 Replies
07-10-2012 04:33 PM
I have defined into my code a line and a circle
How do I get the intersection between those 2?
I have the following code but in VS 2010 is telling me this:
 'Public Sub IntersectWith(entityPointer As Autodesk.AutoCAD.DatabaseServices.Entity, intersectType As Autodesk.AutoCAD.DatabaseServices.Intersect, points As Autodesk.AutoCAD.Geometry.Point3dCollection, thisGraphicSystemMarker As Long, otherGraphicSystemMarker As Long)' is obsolete: 'Use the overload taking IntPtr instead.'.
Dim Point11 AsNewPoint3dCollection
Line1.IntersectWith(circle1,Intersect.OnBothOperands, Point11, 0, 0)
It is working but when I will switch to Autocad 2013 I have to use a different method to get the intersection?
ADN Support Specialist
adam.nagy
Message 2 of 4 (212 Views)
Re: I have a line and a circle I want to get the intersection of both
07-10-2012 07:29 PM in reply to: dancalgary
Hi there,
Instead of 0 you'll have to pass in IntPtr.Zero.
Cheers,
Adam Nagy
Autodesk Developer Network
Adam Nagy
Developer Technical Services
Active Contributor
dancalgary
Message 3 of 4 (197 Views)
07-11-2012 06:01 AM in reply to: adam.nagy
Can you please give me an example?
I wasn't able to find any examples about intptr
Active Contributor
dancalgary
Message 4 of 4 (192 Views)
07-11-2012 06:17 AM in reply to: dancalgary
Line1.IntersectWith(circle1,Intersect.OnBothOperands, Point11, IntPtr.Zero, IntPtr.Zero)
I find out what do you mean
