.NET
Distinguished Contributor
vince1327
Message 1 of 9 (242 Views)
Hyperlinks in attribute values and tables
242 Views, 8 Replies
05-15-2012 01:10 PM
Hey guys,
I've been going through older posts with not too much luck. Using C# (VS2010, Acad2012) i've created a block, imported it, given it the required attibute tags and values, and then created an array out of this block for a total of "x" identical blocks for our purposes. As these blocks are desigend to represent real-world products, is there any way that one of my attribute values can reflect a hyperlink to the manufacturers datasheet?
So essentially
Product Info http://www.google.ca/testproduct.pdf
Also, one of my functions lists all of the blocks in the current drawing and tallys them up and drops them into a table where it reports the block name, details, and quantity. I would also like this block name to be a hyperlink as well...is this doable?
Cheers
Vince
*** Edted for spelling and code
AttributeDefinition attDef15 = new AttributeDefinition(new Point3d(0d, 0d, 0d), productinfo, "Web Link", "", db.Textstyle);
                    attDef12.Invisible = true;
ADN Support Specialist
adam.nagy
Message 2 of 9 (222 Views)
Re: Hyperlinks in attribute values and tables
05-15-2012 07:04 PM in reply to: vince1327
You could add a hyperlink to each block reference. The same that you can achieve in the user interface using the HYPERLINK command. With that you can assign a URL to any entity (inc. a block reference) so that if the user hovers above the entity then information with the URL will come up, and if the user presses Ctrl+Click, then the browser comes up with the given URL.
Actually, what you asked should also be possible, i.e. to set an attribute reference's value to a URL, by including a field type called hypertext, e.g. like
%<\AcVar \href "http://www.autodesk.com##www.autodesk.com#0">%
There, again, the user could just click on the attribute text and get to the given website.
I hope this helps.
Adam Nagy
Autodesk Developer Network
Adam Nagy
Developer Technical Services
vince1327
Message 3 of 9 (203 Views)
05-16-2012 05:20 AM in reply to: adam.nagy
Great thanks adam. I've been trying however no luck though, is my hyperlink a string value?
for example:
string url = "%<\AcVar \href "http://www.autodesk.com##www.autodesk.com#0">%"
or is there another way to do this. The first set of quotes encompassing the link tends to throw things off.
Cheers
Vince
Moderator
Alexander.Rivilis
Message 4 of 9 (190 Views)
05-16-2012 09:30 PM in reply to: vince1327
for example:
Cheers
Vince
Maybe like this:
string url = "%<\\AcVar \\href \"http://www.autodesk.com##www.autodesk.com#0\">%";
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
vince1327
Message 5 of 9 (183 Views)
05-17-2012 05:16 AM in reply to: Alexander.Rivilis
Thanks Alexander. When i do this, the URL shows up in my properties window but is not clickable...is this normal?
Cheers
Vince
Moderator
Alexander.Rivilis
Message 6 of 9 (181 Views)
05-17-2012 05:29 AM in reply to: vince1327
What about Ctrl+Left Mouse Button click on attribute in drawing?
vince1327
Message 7 of 9 (178 Views)
05-17-2012 05:33 AM in reply to: Alexander.Rivilis
That doesn't seem to be working...It seems as though the hyperlink isn't being treated any differently than any other attribute. I can click it, select it, etc....but it doens't behave as a hyperlink, just as a standard attribute.
Valued Mentor
fieldguy
Message 8 of 9 (170 Views)
05-17-2012 09:48 AM in reply to: vince1327
Try the attached.  It needs to be inserted into some drawing.
vince1327
Message 9 of 9 (165 Views)
05-17-2012 09:57 AM in reply to: fieldguy
Thanks fieldguy...so that does work...but i think i'm just explaining this badly...What i'm trying to do is get the attribute value that shows up in the property window to be clickable. I know how to create hyperlinks in the drawing itself, but is it possible to make an attribute value a hyperlink? So that way if i click a filter for instance, the model number, size, etc, all pop up as attributes in the properties window, and then i have a hyperlink there that links directly to the manufacturers datasheet
Cheers
Vince
