.NET
Valued Contributor
fsztuczny
Message 1 of 8 (397 Views)
Howto modify DXF codes inside entities?
397 Views, 7 Replies
04-17-2013 11:50 PM
For example I need change only DXF 30 inside polyline without using API.
Moderator
Alexander.Rivilis
Message 2 of 8 (380 Views)
Re: Howto modify DXF codes inside entities?
04-18-2013 03:29 AM in reply to: fsztuczny
What do you mean "without using API"?
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Valued Contributor
fsztuczny
Message 3 of 8 (378 Views)
04-18-2013 03:42 AM in reply to: Alexander.Rivilis
Hatch modified by the API (Elevation - DXF code 10) was not physically at a preset level. I saved the DWG file to DXF file. Hatch had a DXF code 10 set, but the code 30 had a value that reflects the actual position. I would like to change code DXF directly.
Moderator
Alexander.Rivilis
Message 4 of 8 (373 Views)
04-18-2013 04:10 AM in reply to: fsztuczny
With help of P/Invoke next functions you can do it:
acdbGetAdsName
acdbEntGet
acdbEntMod
acdbEntUpd
Valued Contributor
fsztuczny
Message 5 of 8 (367 Views)
04-18-2013 04:39 AM in reply to: Alexander.Rivilis
Is the p / invoke is portable between different versions of AutoCAD?
Moderator
Alexander.Rivilis
Message 6 of 8 (365 Views)
04-18-2013 04:46 AM in reply to: fsztuczny
You can do it portable if you check AutoCAD version (Application.Version) and x86/x64
As a example: http://forums.autodesk.com/t5/NET/Determine-32-or-64-bit-application/m-p/3748030#M32834
Valued Contributor
fsztuczny
Message 7 of 8 (355 Views)
04-18-2013 05:44 AM in reply to: Alexander.Rivilis
Thank you.
Valued Contributor
fsztuczny
Message 8 of 8 (286 Views)
05-03-2013 08:54 AM in reply to: fsztuczny
Would you give an example of how to do this in C# ?
