.NET
Howto modify DXF codes inside entities?
7 REPLIES 7
Message 1 of 8
fsztuczny
858 Views, 7 Replies
For example I need change only DXF 30 inside polyline without using API.
7 REPLIES 7
Message 2 of 8
What do you mean "without using API"?
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 3 of 8
Hatch modified by the API (Elevation - DXF code 10) was not physically at a preset level. I saved the DWG file to DXF file. Hatch had a DXF code 10 set, but the code 30 had a value that reflects the actual position. I would like to change code DXF directly.
Message 4 of 8
With help of P/Invoke next functions you can do it:
acdbGetAdsName
acdbEntGet
acdbEntMod
acdbEntUpd
Expert Elite Member
Message 5 of 8
Is the p / invoke is portable between different versions of AutoCAD?
Message 6 of 8
You can do it portable if you check AutoCAD version (Application.Version) and x86/x64
As a example: http://forums.autodesk.com/t5/NET/Determine-32-or-64-bit-application/m-p/3748030#M32834
Expert Elite Member
Message 7 of 8
Thank you.
Message 8 of 8
fsztuczny
in reply to: fsztuczny
Would you give an example of how to do this in C# ?
”Boost
