SelectCrossingWindow() is just a wrapper around
acedSSGet("c",...), and that's where the limitation is.
So, if you mean to select objects within a given
boundary, directly calling acedSSGet() isn't going
to give you any different results.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
wrote in message news:5581728@discussion.autodesk.com...
Good morning,
I was writing code that selected objects using SelectCrossingWindow() and noticed that the function only selects entities with geometric extents completely visible in the current viewport.
I want to select from the entire database (limited to modelspace).
To do this it looks like I need to import acedSSGet() but I am unsure how to do it. Can someone point me in the right direction?
