.NET
How to using Modeless form in AutoCAD
2 REPLIES 2
814 Views, 2 Replies
I have a problem.
I want to AutoCAD do not lock it's space, when my Form is shown on display.
But I have an exception when I use modeless dialog.
public void MyCommand ()
  // Using this code, my program works fine, but locks modal space of AutoCAD
  System.Windows.Forms.Application.EnableVisualStyles ();
  System.Windows.Forms.Application.Run (new  Form1 ());
  // I want to use this instruction to do not lock modal space
  // Autodesk.AutoCAD.ApplicationServices.Application.ShowModelessDialog (new Form1 ());
If I use modeless dialog I can read and write from acad prompt and create block; BUT I can't create BlockReference.
I get an exception "eLockViolation" in the next code instructions:
public void CreateBlockReference (string strBlockName, Point3d Origin)
  using( Transaction t = db.TransactionManager.StartTransaction () )
   BlockTable btTable = (BlockTable)t.GetObject (db.BlockTableId, OpenMode.ForRead);  // <--- EXCEPTION
   BlockTableRecord btrModelSpace = (BlockTableRecord)t.GetObject (
     btTable[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
   if( !btTable.Has (strBlockName) )
     ed.WriteMessage (string.Format (msgs.BlockNoExist,strBlockName));
     throw new Exception (ErrorStatus.MissingBlockName,
   ObjectId myBlockId = btTable[strBlockName];
   BlockReference brRefBlock = new BlockReference (Origin, myBlockId);
   btrModelSpace.AppendEntity (brRefBlock);
   t.AddNewlyCreatedDBObject (brRefBlock, true);
   t.Commit ();
  } // end using
Please, help me.
Thank you.
2 REPLIES 2
I found right answer:
/// <summary></summary>
/// <param name="strBlockName"></param>
/// <param name="Origin"></param>
  DocumentLock dl = Application.DocumentManager.MdiActiveDocument.LockDocument ();
  t.Commit ();
  } // end using
  dl.Dispose ();
Daniel.Du
yes, use DocumentLock in a model or modeless dialouge.
Daniel Du
Developer Technical Services
Autodesk Developer Network
”Boost
