.NET
How to use the Menu class?
3 REPLIES 3
313 Views, 3 Replies
Autodesk.AutoCAD.Windows namespace has the Menu class.But how to use it?
3 REPLIES 3
Here's an example:
public class TestObjectContextMenu
public class MyContextMenu : ContextMenuExtension
private MenuItem m_main = new MenuItem("MAIN MENU");
private MenuItem m_sub0 = new MenuItem("SUBMENU 0");
private MenuItem m_sub1 = new MenuItem("SUBMENU 1");
private MenuItem m_sub2 = new MenuItem("SUBMENU 2");
static public bool m_bShowExtraMenus = true;
public MyContextMenu()
this.Title = "Test";
this.MenuItems.Add(m_main);
m_main.MenuItems.Add(m_sub0);
m_main.MenuItems.Add(m_sub1);
this.Popup += new EventHandler(OnUpdateMenu);
m_sub0.Click += new EventHandler(OnClick);
m_sub1.Click += new EventHandler(OnClick);
m_sub2.Click += new EventHandler(OnClick);
void OnClick(object sender, EventArgs e)
void OnUpdateMenu(object sender, EventArgs e)
ContextMenuExtension cme = (ContextMenuExtension) sender;
if (MyContextMenu.m_bShowExtraMenus)
if (!m_main.MenuItems.Contains(m_sub2))
m_main.MenuItems.Add(m_sub2);
else
if (m_main.MenuItems.Contains(m_sub2))
m_main.MenuItems.Remove(m_sub2);
// toggle
MyContextMenu.m_bShowExtraMenus =
!MyContextMenu.m_bShowExtraMenus;
[CommandMethod("MENUTEST")]
public static void DoIt()
Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("Registering
Object Context menu for circle...\n");
MyContextMenu cme = new MyContextMenu();
Application.AddObjectContextMenuExtension(RXObject.GetClass(typeof
(Circle)), cme);
wrote in message news:4894632@discussion.autodesk.com...
Thanks for your answer.But can I use it to create my own popup menus in the menu bar?
No. You should use the COM API to do that (MenuBar, MenuGroup and co) They
work perfectly well from any .NET language.
Albert
wrote in message news:4895840@discussion.autodesk.com...
menu bar?
”Boost
