.NET
How to use SetWindowLong
4 REPLIES 4
Jan1
422 Views, 4 Replies
I'm trying to create a modeless dialog for ACAD 2005 with VB .NET. As I got read in several discussions this should be possible with using the SetWindowLong function. I have tried but could not succeed. Here is my code:
Public Const GWL_HWNDPARENT = (-8)
Public Declare Function SetWindowLong Lib "user32" Alias "SetWindowLongA" (ByVal hwnd As IntPtr, ByVal nIndex As Long, ByVal wNewLong As Long) As Long
Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
Dim appACAD As Autodesk.AutoCAD.Interop.AcadApplication = Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication
SetWindowLong(Me.Handle, GWL_HWNDPARENT, acadApp.HWND)
End Sub
What is wrong with this code? Can anyone please correct it?
Regards, Jan
4 REPLIES 4
fantum
in reply to: Jan1
In your Declare for SetWindowLong, all three parameters and the return type should be Int32. In your call to SetWindowLong, the first argument should be Me.Handle.ToInt32.
Jan1
in reply to: Jan1
Thanks, it works!
NathTay
in reply to: Jan1
If your program is a dll loaded into AutoCAD use the ShowModelessDialog method of the Application object.
Regards - Nathan
in reply to: Jan1
That was introduced in acad 2006 not 2005
wrote in message news:5137111@discussion.autodesk.com...
Regards - Nathan
”Boost
