.NET
How to use SetSystemVariable setting coordinate values
2 REPLIES 2
462 Views, 2 Replies
I have a problem setting sysvar like SNAPBASE, which requires 2d point or 3d point.
I always get wrong input for the following lines. can anybody help to take a look?
 double[] point = new double[2] {5,5};
            object value1 = point;
            Application.SetSystemVariable("SNAPBASE", value1);
what value should I give a 2d point or 3d point?
Please help.
2 REPLIES 2
norman.yuan
The value of system varibale SNAPBASE in .NET API is a Point2d, not a Point3d, nor a double array.
This code works:
        [CommandMethod("SetSB")]
        public static void SetSnapBase()
            Document dwg = Application.DocumentManager.MdiActiveDocument;
            Editor ed = dwg.Editor;
            Point2d sBase = (Point2d)Application.GetSystemVariable("SNAPBASE");
            ed.WriteMessage("SNAPBASE: X={0} Y={1}", sBase.X, sBase.Y);
            Point2d newBase = new Point2d(2.0, 2.0);
            Application.SetSystemVariable("SNAPBASE", newBase);
Norman Yuan
Drive CAD With Code
in reply to: norman.yuan
thanks very much.
it worked well though there's a typo at the last line that should be newbase.Smiley Very Happy
”Boost
