.NET
How to use "copy with base point " using vb.net
3 REPLIES 3
916 Views, 3 Replies
Hi all,
I am just trying to migrate from VBA to VB.net, I want  to know, how we can manipulate the Ctrl+Shift+C, in vb.net, if it is not possible at all, then what is the best way I can find the alternate to this.
OR
If I try to use the wblockclone() then, how do I control the location of the objectcollection when I clone it in my new drawing.
in other words, when I in the proces of clonning I should be able to specify a base point.
I hope you are getting what I am trying to do.
Please help me with this.
Thank you in advance.
3 REPLIES 3
Hallex
Here is semi-solution
Thank you.
Hallex
You're welcome
~'J'~
”Boost
