.NET
How to use GetSubentityPathsAtGsMarker?
3 REPLIES 3
344 Views, 3 Replies
The GetSubentityPathsAtGsMarker function has a parameter named marker,but I don't know how to set it.
3 REPLIES 3
The GS marker is used by the viewportDraw/worldDraw implementation of
objects. It is stored by the graphics subsystem. There are a couple of
places where we provide you with gs markers: one of them is the
SelectedObject.GraphicsSystemMarker property. You can also implement the
Autodesk.AutoCAD.GraphicsInterface classes yourself and pass your
implementation to worldDraw to find out what GS markers are sent down.
Albert
wrote in message news:4894581@discussion.autodesk.com...
I select a solid and want to get its gs markers.How to do this by using the SelectedObject.GraphicsSystemMarker property?
You can get the gs marker for the "subentity" that you used to select the
object (the edge that you picked on). You can't get all the gs markers this
way (unless you click on all edges individually one after another.
Albert
wrote in message news:4896025@discussion.autodesk.com...
”Boost
