.NET
How to use CloseAndSave in 2013?
3 REPLIES 3
classof
468 Views, 3 Replies
hi ..
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.EditorInput
Public Class DocumentTest
    <CommandMethod("CD")> _
       Public Sub Main()
        Dim dm As DocumentCollection = Application.DocumentManager
        Dim ActiveDoc As Document = dm.MdiActiveDocument
        For Each doc As Document In dm
            If doc <> ActiveDoc Then
              DocumentExtension.CloseAndDiscard(doc)
           Else
           DocumentExtension.CloseAndSave(doc, "C:\DocumentTest.dwg")     ' ERROR
      Next
    End Sub
End Class
please help me~~
3 REPLIES 3
Alfred.NESWADBA
in reply to: classof
have you searched/found >>>this thread<<< 😉
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
_gile
The DocumentExtension class provides extension methods.
You can have a look to these threads to know a little more about this:
http://msdn.microsoft.com/en-us/library/bb383977%28v=vs.100%29.aspx
http://msdn.microsoft.com/en-us/library/bb384936.aspx
Gilles Chanteau
GileCAD
GitHub
classof
in reply to: Alfred.NESWADBA
 Thanks for your reply.
I just want to know that “DocumentExtension.CloseAndSave(doc, “C:\DocumentTest.dwg”) is correct code.
And if correct, why the error has occurred?
”Boost
