.NET
.NET
Active Member
pucx
Message 1 of 7 (544 Views)
How to use acedssget() function in autocad development using C#
544 Views, 6 Replies
01-06-2013 09:18 AM
How to use acedssget() function(use this function to select by crossing polygon) in autocad development using C# ,thank you!
What about Editor.SelectCrossingPolygon method?
Moderator
Alexander.Rivilis
Message 2 of 7 (539 Views)
Re: How to use acedssget() function in autocad development using C#
01-06-2013 09:27 AM in reply to: pucx
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Active Member
pucx
Message 3 of 7 (494 Views)
01-09-2013 02:55 AM in reply to: Alexander.Rivilis
I want to use acedssget to achive Editor.SelectCrossingPolygon .thank you!
Moderator
Alexander.Rivilis
Message 4 of 7 (491 Views)
01-09-2013 03:34 AM in reply to: pucx
Do I understand correctly that Editor.SelectCrossingPolygon satisfy you?
Active Member
pucx
Message 5 of 7 (476 Views)
01-10-2013 12:52 AM in reply to: Alexander.Rivilis
yes,but in cad2006 the .net method some times can't achive the result.
Moderator
Alexander.Rivilis
Message 6 of 7 (472 Views)
01-10-2013 01:11 AM in reply to: pucx
Do you know that all points passed to the method Editor.SelectCrossingPolygon should be visible on the screen (current viewport)?
Active Member
pucx
Message 7 of 7 (426 Views)
01-16-2013 02:39 AM in reply to: Alexander.Rivilis
I use this function behind zoomextents()....
