.NET
How to use acedssget() function in autocad development using C#
6 REPLIES 6
1310 Views, 6 Replies
How to use acedssget() function(use this function to select by crossing polygon) in autocad development using C# ,thank you!
6 REPLIES 6
Alexander.Rivilis
What about Editor.SelectCrossingPolygon method?
Facebook | Twitter | LinkedIn
Expert Elite Member
in reply to: Alexander.Rivilis
I want to use acedssget to achive Editor.SelectCrossingPolygon .thank you!
Alexander.Rivilis
Do I understand correctly that Editor.SelectCrossingPolygon satisfy you?
Expert Elite Member
yes,but in cad2006 the .net method some times can't achive the result.
Alexander.Rivilis
Do you know that all points passed to the method Editor.SelectCrossingPolygon should be visible on the screen (current viewport)?
Expert Elite Member
I use this function behind zoomextents()....
”Boost
