.NET
How to store data to Autocad that can read by Navisworks Manage
4 REPLIES 4
AbuFaisal
745 Views, 4 Replies
Hi Everyone,
I want to add additional information to objects create using Autocad.
But I want the data to be read by Navisworks Manage.
How can I put the data? Is it using xdata, NOD or any other type?
I'm using Autocad 2011 and visual express 2010
4 REPLIES 4
Hallex
in reply to: AbuFaisal
Have never used Naviswork but this link would be interesting for you http://adndevblog.typepad.com/autocad/2012/05/serialize-a-net-class-into-an-autocad-drawing-database...
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
AbuFaisal
in reply to: Hallex
Hi Hallex,
I have check to the link above. But its not mention anything about the drawing opened by other software such as Navisworks
Hi, AbuFaisal!
It seems that this question is better to ask in a forum Autodesk Navisworks API
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
@Alexander.Rivilis wrote:
Hi, AbuFaisal!
Ok, I'll ask in Autodesk Naviswork API. Hopefully I can get the answer there
”Boost
