.NET
How to start WPF - application ?
3 REPLIES 3
Shlemazl
516 Views, 3 Replies
Hi all!
I need help. I have .Net Framework 3.5 and AutoCAD2010. but my WPF applicatin do not start. I can do prog by .dll , but don't know how about WPF in AutoCAD.
What should I do ?
3 REPLIES 3
kdub_nz
in reply to: Shlemazl
Without knowing more about your application ,,,,, perhaps try :
http://lmgtfy.com/?q=wpf+AutoCAD
// Called Kerry in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect.
class keyThumper<T> : Lazy<T>;      another  Swamper
hyunseon
I've written posts is a
http://blog.daum.net/cafeofhtewinter/374
is Written an korean
Seoul, South Korea
Balaji_Ram
in reply to: hyunseon
I dont understand Korean. So I am not sure if what you have written in the blog is a question or an answer Smiley Tongue
Anyway, you can find two good presentations on using WPF at the following link :
Using WPF in your applications (Part I and Part II)
http://through-the-interface.typepad.com/through_the_interface/2009/08/hosting-wpf-content-inside-an...
Balaji
Developer Technical Services
Autodesk Developer Network
”Boost
