I was wondering whether there was an easy way to show the user the polygon/fence they are creating when Editor.SelectXX is called by indicating it with a dashed line and coloring the area with a semitransparent fill, kind of like when you use the AREA command or when you click somewhere and AutoCAD shows you the selection window you're creating?
Any thoughts?
Check the Editor method DrawVector, it takes 2 points, a color index and the last argument tells if show the vector highlighted or not.
Gaston Nunez
