.NET
How to set the PrintableArea use .NET?
3 REPLIES 3
489 Views, 3 Replies
Use PlotConfigManager can get the MediaBounds ,but how to set?
Set the paper margins to 0, like this:
Dim acPlConfig As PlotConfig = PlotConfigManager.CurrentConfig
Dim mdb As MediaBounds = acPlConfig.GetMediaBounds("A4")
'mdb.LowerLeftPrintableArea = New Point2d(0, 0)
'mdb.UpperRightPrintableArea = mdb.PageSize
 The code can not solve the problem, what is missing?
Any advice / guidance would be appreciated.
3 REPLIES 3
mcicognani
in reply to: 583408432
Plotting is rather a wide argoument, may I suggest you the plot articles in Kean's blog? There are a few, from simpler to more advanced.
A good starting point would be this: http://through-the-interface.typepad.com/through_the_interface/2007/09/driving-a-basic.html
in reply to: mcicognani
Thank you for your suggestion,but i want to set the MediaBounds(the page margins), not to set the SetPlotWindowArea.
I know Kean's blog, but still can not find what I want.
Balaji_Ram
You cannot change it for an existing media name.
But you can select a media name that is closest to the size that you want.
http://adndevblog.typepad.com/autocad/2012/05/how-to-implement-plotsettingsvalidatorsetclosestmedian...
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
”Boost
