.NET
How to set one palette on a paletteset on top through code?
1 REPLY 1
yaqiz
616 Views, 1 Reply
Hi All,
I have a paletteset which contains multiple palettes. How can I set one of the palette on top through code?
It is something like set current tab in tab control
Any hints?
Yaqi
1 REPLY 1
norman.yuan
in reply to: yaqiz
Palette contained in a PaletteSet is indexed by its order being added into the paletteSet. If you know the index of the pallete, you can call PaletteSet.Activate(index) to activate the palette, or you can loop the PaletteSet with palette name (Palette has a name when being added into PaletteSet):
For i As Integer=0 To myPaletteSet.Count-1
    Dim p As Palette=myPaletteSet(i)
    If  p.Name.ToUpper()="SOMENAME" THEN
        myPalleteSet.Activate(i)
        Exit For
    End If
Next
Norman Yuan
Drive CAD With Code
”Boost
