.NET
How to set customscale or standarscale on a clipped viewport
0 REPLIES 0
Message 1 of 1
JanetDavidson
294 Views, 0 Replies
Hello experts. How can I set customscale or standardscale on a clipped view port. Code below used to work properly when it was a rectangular view port. by the time I changed it to a clipped non rectangular view port scale doesn't set . Any help ?
Thanks , Janet
    Sub clippedVports()
        Dim Mydwg As Document = Application.DocumentManager.MdiActiveDocument
        Dim Mydb As Database = Mydwg.Database
        Dim Myed As Editor = Mydwg.Editor
        Dim tr As Transaction = Mydb.TransactionManager.StartTransaction()
        Using tr
            Dim bt As BlockTable = DirectCast(tr.GetObject(Mydb.BlockTableId, OpenMode.ForRead), BlockTable)
            Dim ps As BlockTableRecord = DirectCast(tr.GetObject(bt(BlockTableRecord.PaperSpace), OpenMode.ForWrite), BlockTableRecord)
            Dim dbobjs As New DBObjectCollection()
            Dim pl As New Autodesk.AutoCAD.DatabaseServices.Polyline(6)
            pl.AddVertexAt(0, New Point2d(4.92, 5.29), 0, 0, 0)
            pl.AddVertexAt(1, New Point2d(5.16, 6.02), 0, 0, 0)
            pl.AddVertexAt(2, New Point2d(6.12, 6.49), 0, 0, 0)
            pl.AddVertexAt(3, New Point2d(7.29, 6.26), -0.27, 0, 0)
            pl.AddVertexAt(4, New Point2d(8.11, 5.53), -0.47, 0, 0)
            pl.AddVertexAt(5, New Point2d(7.75, 5.41), 0, 0, 0)
            pl.Closed = True
            dbobjs.Add(pl)
            For Each dbobj As DBObject In dbobjs
                Dim ent As Entity = TryCast(dbobj, Entity)
                If ent IsNot Nothing Then
                    Dim myobjid As ObjectId = ps.AppendEntity(ent)
                    tr.AddNewlyCreatedDBObject(dbobj, True)
                    Dim vp As New Autodesk.AutoCAD.DatabaseServices.Viewport
                    ps.AppendEntity(vp)
                    tr.AddNewlyCreatedDBObject(vp, True)
                    vp.NonRectClipEntityId = myobjid
                    vp.NonRectClipOn = True
                    vp.CustomScale = 0.003
                    vp.[On] = True
            Next
            tr.Commit()
        End Using
    End Sub
0 REPLIES 0
”Boost
