.NET
.NET
vasantpadhiyar71
Message 1 of 4 (1,239 Views)
How to set Custom File Property without Opening File?
1239 Views, 3 Replies
06-27-2012 01:28 AM
Hi Experts,
By Opening File into AutoCAD I can set the Custom Property(dwgname,dwgid,projectname) of the File.
But I want to set value of these properties without opening AutoCAD application.
I can set it using:
public void SetAttributes(Hashtable hashTable,String fileOpenPath)
            Document Doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.Open(fileOpenPath); //Can we create this Object using any other way??
            Database Db = Doc.Database;
            DatabaseSummaryInfoBuilder DbSib = new DatabaseSummaryInfoBuilder();
            Autodesk.AutoCAD.DatabaseServices.TransactionManager tm = Db.TransactionManager;
                using (Transaction aTran = tm.StartTransaction())
                    foreach (DictionaryEntry entry in hashTable)
                        DbSib.CustomProperties.Add(entry.Key.ToString(), entry.Value.ToString());
                    Db.SummaryInfo = DbSib.ToDatabaseSummaryInfo();
                    aTran.Commit();
Vasant PADHIYAR
Alfred.NESWADBA
Message 2 of 4 (1,234 Views)
Re: How to set Custom File Property without Opening File?
06-27-2012 02:19 AM in reply to: vasantpadhiyar71
Without having a software that can open and modify a DWG-file you can't alter any content in it.
As long as you have no alternative to AutoCAD you have to start AutoCAD. (Otherwise you may buy something like >>>Autodesk's RealDWG<<< or  >>>OpenDwg<<<)
What may help is that you don't need to load the DWG into the editor, you can just open the file-database using
new DatabaseServices.Database and
Database.ReadDwgFile.
- alfred -
Alfred NESWADBA
Valued Mentor
jeff
Message 3 of 4 (1,212 Views)
06-27-2012 08:19 AM in reply to: Alfred.NESWADBA
Maybe ask one the guys over at AdnDevBlog and see if they will provide a link to DWG Properties (DWGPropsX) control
and info on DwgPropsX.dll
You can also find your answers @ TheSwamp
Valued Mentor
jeff
Message 4 of 4 (1,065 Views)
01-08-2013 10:03 AM in reply to: jeff
Here is a start and needs refactoring just thrown together to see if worked, and and have not read it yet but a link to pdf with good info.
http://www.theswamp.org/index.php?topic=43512.0
