.NET
How to set current layer
3 REPLIES 3
HelloWorlddd
556 Views, 3 Replies
How to set current layer to a specified layer? I mean use program complete this function.
For example there is a new layer called "myLayer", then I execute  a command, the currrent layer will be"myLayer".
Any help much appreciated.
3 REPLIES 3
Keith.Brown
in reply to: HelloWorlddd
The easiest way to set the current layer is to modify the CLAYER system variable.
Application.SetSystemVariable("CLAYER", "myLayer");
cdinten
another way is using Database.Clayer property
you just set your specified layer's objectid to this property
HelloWorlddd
in reply to: Keith.Brown
Smiley EmbarassedThanks for your help
”Boost
