.NET
Valued Contributor
0 Kudos
Post 1 of 4
How to set current layer
221 Views, 3 Replies
03-31-2014 04:19 AM
How to set current layer to a specified layer? I mean use program complete this function.
For example there is a new layer called "myLayer", then I execute  a command, the currrent layer will be"myLayer".
Any help much appreciated.
The easiest way to set the current layer is to modify the CLAYER system variable.
Application.SetSystemVariable("CLAYER", "myLayer");
109 Kudos
Post 2 of 4
Re: How to set current layer
03-31-2014 04:30 AM in reply to: HelloWorlddd
Keith Brown AutoCAD MEP BLOG | RSS Feed
AutoCAD MEP 2014 | Revit 2014 | EastCoast CAD/CAM V6.1 | Visual Studio 2013
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate. Thank you!
Valued Contributor
0 Kudos
Post 3 of 4
03-31-2014 05:02 AM in reply to: HelloWorlddd
another way is using Database.Clayer property
you just set your specified layer's objectid to this property
Valued Contributor
0 Kudos
Post 4 of 4
04-01-2014 04:52 AM in reply to: Keith.Brown
:smileyembarrassed:Thanks for your help
