.NET
$o-olitarY
Message 1 of 7 (719 Views)
How to set a focus to AutoCAD main window from my form of C# .NET plug-in?
719 Views, 6 Replies
12-07-2013 07:40 AM
How to switch focus to AutoCAD document window from my form of C# .NET plug-in.
After user pressed the button, I invite him to input a point, but my form still on top.
And it is nessesary to press minimize button, next to set a Focus on Autocad window, then to pick a point.
It is not handy enough.
I did not find a property to set a focus in class of Application.MainWindow.
How can I do it?
Thank you, in advance.
Assuming the modeless form is launched from an autoCAD command :
 [CommandMethod("Test")]
public void Test()
Application.ShowModelessDialog(new ModelesssForm());
In the ModelessForm class, the button  click event handler may be:
 private void button1_Click(object sender, EventArgs e)
this.Hide(); // this is not mandatory
Document doc = AcAp.DocumentManager.MdiActiveDocument;
Editor ed = doc.Editor;
using (doc.LockDocument()) // this is needed from a modeless form
// set focus to AutoCAD
Autodesk.AutoCAD.Internal.Utils.SetFocusToDwgView();
// do your stuff here
PromptPointResult ppr = ed.GetPoint("\nPick a point: ");
this.Show(); // this is mandatory if the form have been hidden
SENL1362
Message 2 of 7 (711 Views)
Re: How to set a focus to AutoCAD main window from my form of C# .NET plug-in?
12-07-2013 08:17 AM in reply to: $o-olitarY
:::Form1.cs:::
private void Cancel_Click(object sender, EventArgs e)
this.Close();
private void Select_Click(object sender, EventArgs e)
Document doc = Acad.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
using (EditorUserInteraction preventFlikkering = ed.StartUserInteraction(this))
PromptPointOptions getPntPrmpt = new PromptPointOptions("\nGet Center");
//Modal Form: will hide because of ed.GetPoint
PromptPointResult getPnt = ed.GetPoint(getPntPrmpt);
ed.WriteMessage("\nPoint: {0}", getPnt.Value);
ed.Regen();
preventFlikkering.End();
$o-olitarY
Message 3 of 7 (701 Views)
12-07-2013 10:51 AM in reply to: SENL1362
Thanks, but I'm using modeless autocad dialog method.
Is there explicit call of any method to change a focus?
SENL1362
Message 4 of 7 (693 Views)
12-07-2013 01:44 PM in reply to: $o-olitarY
[DllImport("user32.dll")]
private static extern System.IntPtr SetFocus(System.IntPtr hwnd);
//For Modeless Forms
System.IntPtr hwnd = adsw_acadDocWnd();
SetFocus(hwnd);
//Required when Modeless form
using (DocumentLock theLock = Application.DocumentManager.MdiActiveDocument.LockDocument())
_gile
Message 5 of 7 (683 Views)
12-08-2013 12:50 AM in reply to: $o-olitarY
        public void Test()
Gilles Chanteau
$o-olitarY
Message 6 of 7 (679 Views)
12-08-2013 12:59 AM in reply to: SENL1362
What library should I to import to use adsw_acadDocWnd () function?
$o-olitarY
Message 7 of 7 (676 Views)
12-08-2013 01:11 AM in reply to: _gile
Thank you very much.
I searched th solution for a month. Now it is exactly what I need.
